Radiation or humidity? It was definitely a humid day yes, dense fog this morning and still a humid feel this afternoon. At the time of the error, RH was around 95% and it only just started to decrease from ~100% about an hour earlier. Solar radiation was 250-350 W/m².
This isn't a brawl!
I find your arguments and deductions a bit flimsy.
This is a shelter comparison, and all quality shelters will give very similar Tn and Tx.
In a shelter, two parameters (for our technical and financial level) are possible: one is absent (humidity).
In the immediate environment, two parameters are possible: one is absent (radiation), the second is debatable (wind).
We may have our grievances against Barani, but I think Jan knows what he's talking about:
"it's better to have the values as close as possible to the shelters".This type of test set-up is found in other manufacturers, and I seem to have seen it at Apogèe.
From memory, your WeatherWise system has several channels, so why not fit an SHT?
A simple WS68 on your wooden stem will give you wind and radiation, ok it's not a pyro but the aim is to know the evolution of the radiation and not to know if it's 300w or 320w.
A simple GW1000 and you have enough to analyse with real data, a GW works with solar energy (I did the test for the Italians).
We all know that Belgium is full of water and we're in the autumn, so it's a shame to get bogged down in these habits.
For example, yesterday I realised that the FARS was going to have problems with the humidity coming from the ground, and I remember Jan's advice about a radiant shelter, so I'm probably going to 'recycle' my Rad14 into a radiant.
To minimise errors, I'll talk to Jan about determining the right height.
Have a good Sunday.
