Author Topic: WD and Ecowitt HP-10 webcam  (Read 1268 times)
Offline MM0ZIF
  • Radio-Amateur MM0ZIF
    • MM0ZIF-WX
« on: August 24, 2024, 01:57:04 PM »
Hi all,
I've been beating myself to death with this, it might seem intuitive to others, but to me, nope. I bought a Ecowitt HP-10 camera and am having great difficulties configuring it with weather display. Has anyone had any joy or any tips to point me in the right direction?
Offline R.Sidetrack
Re: WD and Ecowitt HP-10 webcam
« Reply #1 on: August 24, 2024, 02:30:07 PM »
It would be useful to have more details on what doesn't work for you.
Is your camera successfully publishing images to Ecowitt.net?  Perhaps it would be useful to review this info page:
http://meshka.eu/Ecowitt/dokuwiki/doku.php?id=start&s[]=camera#hp10_wittcam_weather_camera
Edit: looks like the forum software doesn't like that link format. Here is the same link except I intentionally corrupted the link activation by making the 4th character "x" instead of the correct "p".  So you can paste that text into your browser and fix the spelling before you press Enter, or just search the active page link for "HP10" until you find the camera info.
httx://meshka.eu/Ecowitt/dokuwiki/doku.php?id=start&s[]=camera#hp10_wittcam_weather_camera
« Last Edit: August 24, 2024, 02:40:48 PM by R.Sidetrack »
Graham
--- Variety of Ecowitt devices ---
Offline rikostan
  • My Wi-Fi is pine scented.
    • East Bay Weather
« Reply #2 on: August 24, 2024, 05:27:00 PM »
I go into the Weather Display folder and find the wdwebcamcapture program. Once it's open, I go to the  "IP camera Setup" tab and click "I want to use an IP camera', then input the URL to your HP10. it will be http://192.168.xxx.xxx/capture with the Xs replaced with your network address. Then I go into the Weather Display Control Panel, find Webcam and make any changes, like overlays or file locations, etc.
I'm not saying this is the best way to do it, but it's how I have done it for the last couple of months since getting the camera, and no complaints.
Ecowitt
WS90
WS2000 Gateway
WH40
WH51
WH75
HP10
Acurite 5-1 Iris
Tropo Manual Rain Gauge
Netatmo (HEY I GOT IT FOR $20!)
Weather Display
Offline MM0ZIF
    • MM0ZIF-WX
« Reply #3 on: August 25, 2024, 01:33:28 PM »
ok, so the stream is detecting in WebCamCapture, I set the directory to H:\wdisplay\webfiles\ and the file name to MainCam.jpg I check the file and it is being created and updated.
 then I go to WD Ito control panel, Web Cam, Timestamping is enabled (switch green), The Java Cam page is set to a directory that is accessible on my server, create files is enabled, and upload Timestamped files is also enabled. So everything there seems fine, I then goto update all webfiles etc, then check with the remote FTP server and nothing is getting as far as the remote server. Obviously the other data for running my site is being uploaded constantly, but not the Webcam.
Am I missing something?
I am also noticing that weather display is pausing regularly (Becoming non-responsive)
Offline rikostan
    • East Bay Weather
« Reply #4 on: August 25, 2024, 04:00:19 PM »
In the FTP and Connections part of the Control Panel, check out the Web Cam upload tab. I have all my cam images listed there as well as their upload times.
It sounds like you're super close!
Ecowitt
WS90
WS2000 Gateway
WH40
WH51
WH75
HP10
Acurite 5-1 Iris
Weather Display
Offline MM0ZIF
    • MM0ZIF-WX
« Reply #5 on: August 25, 2024, 05:01:19 PM »
Enabled the webcam setup page, hit test upload, Nothing still. the selected file is the correct one being pulled by the WebCamCapture app, biggest problem is that Weather Display keeps freezing :S
