Author Topic: PC Mover  (Read 2501 times)
Offline BKS97
    • Sartell East Weather
PC Mover
« on: July 03, 2024, 08:10:50 AM »
I am thinking about buying a new laptop with Windows 11 to replace my old one with Windows 10.  Has anyone used PC Mover to transfer data to a new computer, particularly about how it works moving Weather Display? Thanks.
Offline zeppline
    • Las Vegas Weather Guy
Re: PC Mover
« Reply #1 on: July 03, 2024, 10:55:53 AM »
Yes it is a good program, I have used it three times. I use the one with the with 485 cable. Clean out all the old junk before you transfer or the junk will on your new computer.
Offline BKS97
Re: PC Mover
« Reply #2 on: July 03, 2024, 11:03:25 AM »
Good to know.  Thanks for the information.
Offline broadstairs
Re: PC Mover
« Reply #3 on: July 03, 2024, 11:17:47 AM »
You will probably need to contact Brian Hamilton to register your new PC for WD.
Stuart
Offline Vasco
    • PWS
Re: PC Mover
« Reply #4 on: July 03, 2024, 11:20:23 AM »
. . . particularly about how it works moving Weather Display?
One of the steps in moving WD to another computer involves copying the WD registry entries (see FAQ at https://discourse.weather-watch.com: go to Docs topics from the top line). Will PC Mover do that, or will you still have to double-click wdisplayftp.reg as described in the FAQ?
« Last Edit: July 03, 2024, 11:45:25 AM by Vasco »
Offline BKS97
Re: PC Mover
« Reply #5 on: July 03, 2024, 12:08:36 PM »
Stuart, Vasco -- thanks for the information.  I will look into all of this before I proceed.
Offline broadstairs
Re: PC Mover
« Reply #6 on: July 03, 2024, 12:28:12 PM »
You may need to wait until you get WD running on the new PC IIRC I think Brian needs a code from the new PC. Not absolutely sure nowadays as I no longer use WD.
Stuart
Offline zeppline
Re: PC Mover
« Reply #7 on: July 03, 2024, 01:06:56 PM »
I have moved from Win7 to 10 to 11 and have not got a new code. Just try, it you mite not need it.
