Author Topic: Got the bug and need more help  (Read 3165 times)
Offline Ahill
« on: April 04, 2024, 03:31:12 PM »
So got my ambient station setup and linked to cwop and everything is fine. But living in a tropical storm/hurricane prone area no fun if you cant log extreme weather.
Unfortunately the ambient is only rated for 89 mph so i bit the bullet and went with a VP2.
Is it possible to have broth running basically side by side and report to cwop being in the same location and is a separate madis ID needed? I had to also figure out the elevation pressure using madis to setup everything. Would the whole process need to be done again for the vp2.
« Last Edit: April 04, 2024, 07:06:48 PM by Ahill »
