Author Topic: WiFi Logger 2 Stopped working- no comms- just blinks green  (Read 3843 times)
Offline Bobvelle
    • Fairfield Weather Station
« on: October 12, 2023, 05:58:44 AM »
New Wifi Logger2 stopped working, not reachable via wifi, not sending data. The green Led flashes once every second. It's been on-line with no issues for a little over a month then nothing.
I tried.
Reset (white button} --nothing
complete console reboot---nothing
what does the blinking green LED indicate? And does pressing the red one for 10 sec factory reset it or does it retain the data reporting upload settings?
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
Re: WiFi Logger 2 Stopped working- no comms- just blinks green
« Reply #1 on: October 12, 2023, 11:06:47 AM »
This video shows how to factory reset.
https://www.youtube.com/watch?v=eyWrdPouS0o
My Green LED is on solid while connected.
If it is flashing it is in some other state.
Have you tried Smart Config? I like how it works.
https://www.youtube.com/watch?v=zTLfSWNApew
« Last Edit: October 12, 2023, 11:08:44 AM by davidmc36 »
Offline Bobvelle
« Reply #2 on: October 12, 2023, 06:54:10 PM »
So I tried the red config button- logged into the wifi logger SSID and checked, everything was correct. I reset it and still would not connect to my network. So I rebooted my router and about 10 minutes later the LED was steady green and uploading to the sites again. I have about 8 other wifi devices that are always on this same network, and none of them were having issues, only the WiFi Logger.
I don't understand why, in the middle of the night, after being on-line for weeks, it just decides to just drop off the LAN.
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #3 on: October 13, 2023, 02:13:12 PM »
It is mysterious to me also. I had that happening a few times. After upgrade to 2.42 FW the issue seems to have stopped. Although, a click of white reset brought mine back to life when it did happen.
« Last Edit: October 13, 2023, 02:17:29 PM by davidmc36 »
Offline Bobvelle
« Reply #4 on: October 13, 2023, 02:20:12 PM »
This happened on version 2.42
the only change I made yesterday, when i got it working again, was to set it back to DHCP instead of static. Maybe it will help... IDK
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #5 on: October 13, 2023, 03:04:31 PM »
I think mine is much better on Static IP. The Mesh seems to like reboot cycles and I changed a bunch of things to Static and they seem to reconnect more consistently.
Offline WheatonRon
    • WUnderground
« Reply #6 on: October 13, 2023, 11:46:29 PM »
If all else fails, contact the developer, Wojtek, support@wifilogger.net. He lives in Poland and is very responsive.
« Last Edit: October 13, 2023, 11:48:00 PM by WheatonRon »
Offline WiFiLogger
« Reply #7 on: February 28, 2024, 06:56:30 AM »
I tried.
What it solved? Do you still need any help?
