I expect some of you repair your own weather station hardware?
I bought an Ecowitt station on eBay as "new, opened but unused" and found it to be faulty
The seller refunded me in full and said not to return it. So I have no financial loss, some loss of time spent trying to get it working, compensated by being left with some working parts namely GW1100 gateway, rain gauge, and temp/humidity meter.
I'd like to get the WS68 anenometer working, but it appears dead and won't register with the gateway. Change of batteries, reset button pressing, trying to reregister in app, no signs of life whatever I did. As it was now officially scrapped there seemed nothing to lose so I took it apart and found the 3 farad supercapacitor dangling by one leg. The other leg had never been soldered to the board. The leg had been tinned, but the copper pad on the board was not tinned.
I soldered it back in place, and put it in the sun for the solar panel to charge it up. And indeed over a few hours the voltage across the super capacitor increased gradually from about 0.4v to over 4v.
But still (after installing a lithium battery in the battery compartment) it will not register with the gateway and shows no signs of life.
Am I missing a trick, something obvious? Are there any common/known faults I should look for? I guess a likely possibility given the failure to properly solder the capacitor might be a more widespread problem with soldering and dry joints on the PCB. I'm not set up for soldering surface mount components or doing a proper reflow. I do have a largish heat gun on which I can set the temperature, so there may be nothing to be lost by removing the board from the case and trying to reflow with my heatgun? (what temperature should I use?)
Or perhaps it is time to buy a replacement WS68 direct from Ecowitt, using the eBay refund to pay for it!
Any thoughts welcome.
