Weather Software => WeeWX Software => Topic started by: cou2vent on May 28, 2020, 09:25:06 AM
For a customized weather internet page I need the wind direction generated from WeeWX.
How do I get directly the wind direction please?.
In the index.html report "Current Conditions" I see
<tr>
<td class="label">Vent</td>
<td class="data">0 km/h N/A ( N/A)</td>
</tr>
Where does it come from please?
What do I invoque to get the wind direction on its own?
And I just want the rose ordinals like SE, ENE, etc.
According to the WeeWX customizing guide, the value I am looking for is
$current.windDir.ordinal_compass
How do I get it please?
You get wind direction by putting exactly what you have written into the template:
For example, I have the following in https://www.paloaltoweather.com/weatherboard/
<td id="windSpeedAndBearing" style="font-family:monospace;font-size:105px;text-align:center;">$current.windSpeed $current.windDir.ordinal_compass</td>
Of course, if there is no wind (the example you show), then there is no wind direction. Your example is being generated by this in skins/Seasons/index.html
<tr>
<td class="label">$obs.label.wind</td>
<td class="data">$current.windSpeed $current.windDir.ordinal_compass ($current.windDir)</td>
</tr>
In this example, your getting both the compass direction and numeric value; but, since wind is 0, direction is meaningless.
If you are always showing 0 for wind (and presumably there is actually wind), that is a different story; but unrelated to showing wind direction.
Cheers,
John Kline
Thank you very much John.
I kind of suspected what you say, but now I am sure!
And my html page is ready with $current.windSpeed , etc... where I need them.
WeeWX is rather clever to understand what is required so simply!
My problem now is how do I call my customized html page because I want to keep the existing index.html? In fact I want 2 WeeWX reports generated from the same data.
These 2 reports will be 2 distinct pages and visitors will toggle from one to the other.
http://www.sevestre.net/Rasp/index.html
and http://www.sevestre.net/Plug/indexSevestreFontanes.html (broken at the moment)
One last question. I changed moon phases (in French) in weewx.conf to no avail. Do you know how to overcome this? I did not find any other file with moon phases and therefore could not try to translate. I am talking about "Last quater" that appear under SUN & MOON in your slick Palo Alto page https://www.paloaltoweather.com/
By the way congratulations about this page.
You can add more templates (templates generate pages) to either skin.conf (where they will be overwritten on an update) or to weewx.conf.
To add to weewx.conf:
[[SeasonsReport]]
[[[CheetahGenerator]]]
[[[[ToDate]]]]
[[[[[newpage]]]]]
template = newpage.html.tmpl
As for translation, although I *think* I can answer that, it’s best if you asked someone who has done this sort of thing in WeeWX. It’s best if you asked on http://groups.google.com/group/weewx-user
John,
How to execute the scheme you are proposing in weewx.conf only to overcome the overwritting problem at update?
It looks like it is only possible in Seasons skin.conf.
[CheetahGenerator]
[[ToDate]]
[[[newpage]]]
Along with a reference in weewx.conf but which one? It already says
[[SeasonsReport]]
# The SeasonsReport uses the 'Seasons' skin, which contains the
# images, templates and plots for the report.
skin = Seasons
enable = true
And will weewx generate the newpage.html and put it all right in /var/www/html/weewx/ to be FTPed to the internet server?
As far as translation is concerned, I am not member of Google's group and do not intend to be.
I'll keep searching for the moon phases translation. It's only a detail anyway.
Jean-Paul
With no problem WeeWX generates the classic Seasons, Smartphone and Mobile pages.
I tried to produce an additional web page without success, .
WeeWX does not generate the corresponding index.html file in /var/www/html/weewx/meteofontanes.
In weewx.conf there is
[ MeteoFontanesReport ]
skin = MeteoFontanes
enable = true
HTML_ROOT = /var/www/html/weewx/meteofontanes
and in MeteoFontanes skin.conf there is
[CheetahGenerator]
encoding = html_entities
[[ToDate]]
[ MeteofFontanes ]
template = index.html.tmpl
File permissions look OK.
Any idea what I am doing wrong to produce this additional reportplease?
Error 404.
Curious, though, that so many people read this page and that there is only one person trying to help. Should I rephrase my question?
Why doesn't WeeWX generate the requested report when it generates 3 other reports: Seasons, Smartphone and Mobile?
There must be a specificity in the requested report that WeeWX doesn't like, but what is it? Do you have an idea?
I just started with WeeWx yesterday and I was curious about your question.
Possibly because the official WeeWX user support forum is at http://groups.google.com/group/weewx-user
Gary
Possibly yes, but I am not member of google's group and do not intend to join the group.
Oh, well good luck then.
Gary
If the same misadventure happens to you, change [Celestial] to [Almanac] in weewx.conf and everything will return to normal.
Moon phases in your language will appear!
