Author Topic: Weather 28  (Read 263 times)
Offline Joop2
    • Weerstation Genderen
Weather 28
« on: June 08, 2025, 06:40:34 AM »
Due to a malfunction I lost my Weather28 page. Who can help me with a copy of Weather28?
Offline wvdkuil
  • Wim van der kuil
Re: Weather 28
« Reply #1 on: June 08, 2025, 10:14:03 AM »
When i check your website, I did not find any link to an old "weather28" / "Leuven template" website.
There is no "Leuven template" available anymore. The remaining users of "weather28" have have heavily modified there versions.
But the "Personal weer" menu shows  PWS_Dashboard is malfunctioning also.
When I use debug mode a fatal error occurs inside the settings script.
Error occurs at PWS_settings.php line 255
if (function_exists (mb_internal_encoding) ) {mb_internal_encoding('UTF-8'); }Looks a switch to PHP 8.x shortly?
You can comment line 255-> 259 and check if the error persists.
If you continue to have problems with PWS_Dashboard you can use the Dutch weather-forum and post your problem there.
Or use the "English" forum https://discourse.weather-watch.com/ .
Succes,
Wim
