Author Topic: Saratoga: Wind Averages & Wind Run Script Needed  (Read 484 times)
Offline lakelaurashawn
« on: May 17, 2025, 06:08:14 PM »
Good Afternoon - Huge thanks in advance.  It has been years since I spent anytime managing or updating my weather site and the neglect shows!  Here is my site:  http://www.lakelaurashawn.net
This is the first of several threads to repair broken links, update the look, point to corrected locations and update to the latest version of PHP.
I was able to update to 10.37s Build 152 - so that is current and working.
In the image below there are three new fields I’d like to add and some verbiage corrections.  I also would like to add in the Wildwood Weather wind reports, as seen here: https://weatherwildwoodnaturist.us/wxwinddetail.php?
1. Insert 60-minute average
2. Insert 120-minute average
3. Insert Wind Run
4. Rename Max gust
5. Rename month
Can I please get guidance on which script contains this information and how to publish it on my site?
Lake
« Last Edit: May 17, 2025, 06:44:07 PM by lakelaurashawn »
Offline Vasco
    • PWS
Re: Saratoga: Wind Averages & Wind Run Script Needed
« Reply #1 on: May 18, 2025, 10:04:06 AM »
As mentioned elsewhere, it might be better to update the whole site before adding things. Run check-fetch-times.php?show=versions to see what's available.
