Author Topic: Best antenna/range - WH2650 or WH2910  (Read 290 times)
Offline flygpagen
« on: July 10, 2024, 03:28:57 AM »
Hi! I have just ordered a replacement wxstation that comes with a WH2650/2680 wifi console. I already have a WH2910C, but I don´t really need a display because all it does is forward data to a RBpi. I just wonder if the reception from the sensor console is better on the older WH2650, or if I should keep the WH2910C. It is appr. 100 meters between sensor console and wifi console which has worked fine.
Online Gyvate
Re: Best antenna/range - WH2650 or WH2910
« Reply #1 on: July 10, 2024, 08:34:56 AM »
you can use both, the WS2910 and the WH2650 in parallel - the RF reception of the WH2650 (depending on location) could be slightly better than the WS2910. What improvements the WH2680 version comes with compared to a WH2650 is still under inquiry as it is not an officially published product of Fine Offset / Ecowitt - maybe an upgrade for resellers only.
Can you share the link to where you ordered the WH2680 ?
WS2350 1.6.7, GW1000(3) 1.7.7,WH2650 WiFi (2) 1.7.7 (test/backup), GW1100 2.3.2, GW1200 1.3.1, GW2000(3) 3.1.3, HP2551 1.9.6,5.1.6;HP3500 1.7.2,WS3800 1.3.0, WN1910 1.2.3,WN1980 1.2.3;
Ecowitt WS90(2)1.4.3/1.4.0, WS80(2)1.2.8, WS68, WS69, WH40,WH31,WH31-EP,WN30,WN34L,WN35,WH32,WH32-EP, WH32B, WH57 [Lightning], WH41[PM2.5], WH51, WH45, WH55
MeteobridgePro(2)[test,prod] 5.8 Mar 01 2024, 15185 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3283/Meteobridge RPi4B-2GB,
Barani Meteoshield Pro, MetSpecRad02
weather landing page: http://meshka.eu
WIKI http://meshka.eu/Ecowitt/dokuwiki
Offline R.Sidetrack
« Reply #2 on: July 10, 2024, 10:00:19 AM »
 :D I was amused to see that there is a WU member page in Austria that says their equipment is an "Ecowitt WH2680". See: https://www.wunderground.com/dashboard/pws/IYBBSA10
Graham
--- Variety of Ecowitt devices ---
Offline flygpagen
« Reply #3 on: July 10, 2024, 10:50:13 AM »
Its from Expondo, however their payment system is a bit havoc so it’s still to be decided if the order works… sorry about the W* mixup, I just looked in the compatibility matrix and maybe called it wrong. https://www.expondo.se/steinberg-systems-wifi-vaederstation-utomhussensor-inomhussensor-10030583
Online Gyvate
« Reply #4 on: July 10, 2024, 01:14:01 PM »
the Steinberg Systems station (sold via expondo - these days 109 EUR) is the SBS-WS-600 which so far came with a WH2650 - but the WH2680 might be a hardware upgrade. Waiting for Ecowitt to enlighten me here. They have mentioned this console in some document but nowhere else on their websites.
I have some suspicions but am waiting for Ecowitt to clarify.
Online Gyvate
« Reply #5 on: July 11, 2024, 01:36:01 AM »
WH2650 and WH2680 are th same - they are no longer (were they ever ... ?) listed on the Ecowitt webpage as the WH2650/WH2680 is functionally a GW1000 without the internal T&HP sensor. They have end-of-live status, but the resellers still have a lot of them I guess. Unless you want to use a WS85 or IoT devices, it cover all other Ecowitt sensors, so it's still a powerful piece - and with the extra needed and separtely placeable WH32 indoor sensor, it is more flexible than GW1000.
The new GW1100/GW1200 now have the choice of using the internal or an external T&HP sensor.
If the antenna under the little stick is the WiFi or the RF antenna (or both) I don't know - haven't opened it yet. But I have no reception issues with mine. The distance is not so far, but there are a couple f concrete walls with some sensors.
Design-wise the box is debatable but functionally very good.
The WH2682 (only in the USA resp. only a 915 MHz model) is even better as it has WLAN and LAN interfaces like the GW2000. Its IoT compatibility is still unknown though.
