Author Topic: Saratoga templates and Steel Series Gauges .. now fully work  (Read 14539 times)
Offline weatherdoc
    • Weather Doc's Weather
Re: Saratoga templates and Steel Series Gauges .. now fully work
« Reply #50 on: February 24, 2024, 08:48:51 AM »
My gauges + graphs work: https://novawx.dscloud.me/wxgauges.php. I can provide my scripts if anyone is interested.
« Reply #51 on: March 04, 2024, 12:10:55 PM »
. . . the steel gauges work for me:
But not the graphs?
Nope, the graphs don't work and don't know why.  At least the gauges work.
Offline Vasco
    • PWS
« Reply #52 on: March 04, 2024, 12:23:06 PM »
When I posted you had an error message where the graph should be, which said "Can't find JpGraph directory" or something similar. If you are trying to use @broadstairs' wxgraphs the path is specified in line 20 of graphsconf.php. This is mine:
$jploc = "{$WEBROOT}/jpgraph-4.4.2/src/";  //must have trailing slash
« Last Edit: March 04, 2024, 12:33:56 PM by Vasco »
« Reply #53 on: March 07, 2024, 01:43:33 AM »
Graphs still don't work but no biggie.
Offline vinesweather
    • The Vines Weather
« Reply #54 on: May 09, 2025, 08:11:00 AM »
Hi Mate
I can't get the graphs to work on gauges. Can you tell me which files I ned to look at please?
Many thanks
Chris
Offline Vasco
    • PWS
« Reply #55 on: May 09, 2025, 09:32:41 AM »
The pop-up graphs are not included with SS gauges, you have to instal them separately. There are different trend graphs for different weather programs, but @broadstairs' wxgraphs are usually used with WD. Maybe pick the relevant bits out of this thread.
Up-to-date URL for @weatherdoc's gauges is https://wxdoc.info/wxgauges.php
« Last Edit: May 13, 2025, 07:46:48 PM by Vasco »
Offline weatherdoc
« Reply #56 on: May 10, 2025, 06:43:12 AM »
Hi Mate
Many thanks
Chris
If the thread that @Vasco suggested doesn't solve your graphing issue, I can offer my scripts and possibly help with the configuration. On Weather Watch, my handle is @novawx.
Bill
Offline jaltman
    • Stanley Rapids Weather
« Reply #57 on: May 10, 2025, 04:16:13 PM »
I never tried before to get wxssgauges working, but today i did and all is well except that my windrose is empty.  It works fine in the external page.  I have been staring at code for a while, but don't see why.
https://altlaw.com/saratoga/wxssgauges.php
Jim
« Last Edit: May 10, 2025, 04:19:12 PM by jaltman »
Offline mcrossley
    • Wilmslow Astro
« Reply #58 on: May 10, 2025, 04:47:24 PM »
You are missing a couple of SSGauges scripts: windrose.js and RGraph.radar.min.js
Offline jaltman
« Reply #59 on: May 10, 2025, 05:37:01 PM »
Hmmm.  I don't seem to be able to locate those.  Can you point me to a source? I see some references to them, but the links are old and broken.  Funny that the free standing version works fine.
Thanks.
Jim
Offline Vasco
    • PWS
« Reply #60 on: May 10, 2025, 05:43:05 PM »
Nor can I, in my 2.7.2 download.
Ditto.
« Last Edit: May 10, 2025, 05:47:45 PM by Vasco »
Offline hcorrin
    • Ballaugh Weather
« Reply #61 on: May 11, 2025, 05:10:09 AM »
The RGraph.radar.min.js  should be RGraph.rose.min.js I believe
The windrose.js is proving elusive in the downloads I have checked but I do have it in the gauges scripts folder on my website so I must have got it from somewhere will the other zip files later to see if it’s in one of them
Offline mcrossley
    • Wilmslow Astro
« Reply #62 on: May 11, 2025, 05:15:25 AM »
Those two files are not part of the official distribution.
The "radar" gauge is not a proper SteelSeries gauge; it is something I threw together for my personal web site that uses some custom code and bits of gauges code - mainly the frame - the create something new. It looks like you have a copy of gauges that includes the radar gauge "lifted" from my web site but without all the custom code to go with it.
Offline jaltman
« Reply #63 on: May 11, 2025, 05:35:46 AM »
So, then i gather gather you are not willing to share the files?  Why does the wind rose work fine on the free standing site?
Jim
Offline mcrossley
    • Wilmslow Astro
« Reply #64 on: May 11, 2025, 05:53:37 AM »
The wind rose is part of the distribution, the radar plot is not.
The files are obviously available on my personal gauges web page for anyone who wants to download them, you cannot protect javascript files. But they are unsupported.
Offline Vasco
    • PWS
« Reply #65 on: May 11, 2025, 06:08:11 AM »
@jaltman is only trying to get a windrose  :???:
ReadMe to 2.7.7 download says:
Removing a Wind Rose and Other Optional Gauges
From release 2.0 I have integrated the Wind Rose 'gauge' into the standard 'package', from v2.1.0 it is enabled
by default. . . To disable the Wind Rose you have to make the following changes...
1. Edit gauges-ssT.htm/gauges-ss-basic.htm/gauges-ss-basic-inc.php and delete the 'radar' scripts
towards the end of the document.
       <script src="scripts/RGraph.common.core.min.js"></script>
       <script src="scripts/RGraph.rose.min.js"></script>
2. Edit gauges.js, and change...
     showRoseGauge     : true,
   To...
     showRoseGauge     : false,
That's it, the Wind Rose should now be removed from your page.
Jim: maybe check if you have commented the two scripts mentioned in #1 ?
Offline jaltman
« Reply #66 on: May 11, 2025, 06:24:57 AM »
Yes, Vasco is correct.  I don't really care about the radar portion.  I just want the wind rose like is on my free standing page.  Those two files are not commented out and are present.
But i did just figure it out.  The windrose script references at the bottom of the page did not include the <?php echo $ssgDir; ?>  and the files were not being found.  Its now fine and all is well.
Jim
