Author Topic: firmware update for EasyWeather available: EasyWeatherV1.5.9  (Read 2752 times)
Online olicat
    • FOSHKplugin
« on: April 22, 2021, 06:00:08 AM »
Hi!
There's a new WIFI firmware available (at least for the HP2551C):
EasyWeatherV1.5.9:
1. Optimize domain name resolution.
2. Optimize the uploading stability of custom servers.
I did not test this yet!
The changelog is currently the same as for v1.58 - probably they will change this over time.
This update will be offered while opening the app WS View (if weather station is in the same network as your phone).
Regards, Oliver
Offline Gyvate
Re: firmware update for EasyWeather available: EasyWeatherV1.5.9
« Reply #1 on: April 22, 2021, 09:02:28 AM »
updated one of my WH4000SE (HP2320E) console and will observe.
I didn't observe any upload issues earlier, neither to the Weather networks nor using the customized option.
Online olicat
    • FOSHKplugin
« Reply #2 on: April 22, 2021, 05:32:39 PM »
Hi!
Also installed now on my HP2551C. No problems so far.
Regards, Oliver
Offline Platokidd
  • top side land of Lincoln
« Reply #3 on: April 22, 2021, 11:43:07 PM »
Hi!
Regards, Oliver
So far so good. Didn't noticed anything different. That's probably a good thing...
Ambient
ECOWITT
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
Offline Platokidd
« Reply #4 on: April 22, 2021, 11:47:33 PM »
Prodon my hijack here..
I tried lastnight using the custom option via wsview for my HP2551c. Nojoy. Is it better to do this thru the hp2551c?
Trying to send data to PWS Weather. [ You are not allowed to view attachments ]
« Last Edit: April 23, 2021, 12:00:40 AM by platokidd »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Gyvate
« Reply #5 on: April 23, 2021, 04:16:48 AM »
It doesn't matter - the WSView app is just handier ..
Are you maybe missing a "s" in your path (actually 2)  ;) 8-) ?
Hostname: http://www.pwsweather.com
Path: /pwsupdate/pwsupdate.php
« Last Edit: April 23, 2021, 04:19:21 AM by Gyvate »
Online olicat
    • FOSHKplugin
« Reply #6 on: April 23, 2021, 04:34:18 AM »
Hi!
You must not include "http://" in hostname / ip address!
The station automatically add this in front of the configured line. So if you set it to http://www.pwsweather.com the station tries to send the data to http://http://www.pwsweather.com - which will NOT work.
So: Just set the name or the ip address of the remote server there. Don't include http:// or a slash / at the end of the line!
@platokidd:
The path has to be /pwsupdate/pwsupdate.php as Gyvate mentioned.
So:
Server: www.pwsweather.com (probably just pwsweather.com will also work)
Port: 80
Regards, Oliver
Offline Platokidd
« Reply #7 on: April 25, 2021, 09:59:51 PM »
Thanks for the help.
I have started over creating a new station. But I still have nojoy using the custom server settings. Tried the wsview app and the hp2551.
Maybe the Mods should move this to its own thread.
UPDATE:
Just fount this thread and added /pwsweather.php? (?)
https://www.wxforum.net/index.php?topic=39535.0
Now its initiating.
« Last Edit: April 25, 2021, 10:21:49 PM by platokidd »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Gyvate
« Reply #8 on: April 26, 2021, 03:53:28 AM »
I checked your dashboard and saw that your station sent data for 11 minutes from 09:13 - 09:23 pm on Apr 25. Then it stopped.
Maybe now, with adding the "?" it stopped ?
Things may have changed at the pwsweather end meanwhile (or between a GW1000 and a HP2551, see end of post).
"Initiating" at PWSWeather only means that your data is being checked by PWS quality control during 5 days for being considered consistent.
However, as they use a content management provider, the update only happens (+/-) every 5 minutes (probably with the update interval you chose; i.e. if you chose 60 seconds, every 5 minutes five 1-minute records will be added). At the very start this delay can be bigger.
Your upload without the "?" may have been successful, only you didn't see it yet - and adding the "?" interrupted it.
And you misinterpreted the "initiating" status (which is still on, by the way).
I suggest you start over (in the sense, remove the "?" from the path end, save and wait for an hour and then check your  station dashboard again. It may just work... (re-checking the API key would also be an option - such a long string invites potential typos ...)
The "?" may still be needed, but it's worth a try. The HP2551 console may work slightly different in its posting from a GW1000 with which the tests of the thread you refer to was performed. While the HP2551 has separate WiFi and console firmware, the GW1000 has a "combined" firmware.
« Last Edit: April 26, 2021, 04:05:38 AM by Gyvate »
