Author Topic: FWI Calculator  (Read 38086 times)
Offline wuhu_software
    • WUHU Software Yahoo Group
Re: FWI Calculator
« Reply #50 on: July 28, 2013, 08:27:11 AM »
Contact the author of the FWI calculator and I am sure he can help you out.
Offline mkutche
    • GosportWx.com
Re: FWI Calculator
« Reply #51 on: September 06, 2014, 09:04:44 PM »
Link seems broken can someone share the program??
Mike K.
Gosport, Indiana
Offline JennyLeez
    • Wairoa, HB New Zealand Weather
Re: FWI Calculator
« Reply #52 on: November 02, 2014, 05:59:43 PM »
Links are now back up for the FWI Calculator Software:
http://www.wilddata.org.nz/fwicalc/index.php?page=9&ser=NNF7631T1
Wairoa, Hawkes Bay, New Zealand Weather Station.
http://wairoa.net/weather/index.htm
Offline BeaumarisWX
    • BeaumarisWX
Re: FWI Calculator
« Reply #53 on: November 02, 2014, 06:34:40 PM »
Hi Jenny, Thanks again for your recent assistance.
Just wanted to add that Graeme creator of FWI Calc has a Beta version out. I've been running it live since he created it and works brilliant, worth a look.
regards
Tony Beaumaris, Tasmania (Australia)
CumulusMX GUI : https://beaumaris-weather.com/MXUI/
Saratoga Template : https://beaumaris-weather.com
Offline mkutche
    • GosportWx.com
Re: FWI Calculator
« Reply #54 on: November 02, 2014, 06:56:10 PM »
awesome thanks you guys!! Now to figure out how to use it. :)
Mike K.
Gosport, Indiana
Offline mkutche
    • GosportWx.com
Re: FWI Calculator
« Reply #55 on: November 02, 2014, 08:06:51 PM »
I am stuck am trying to figure out what files i need to upload to my webserver and what not .. :(
Mike K.
Gosport, Indiana
Offline JennyLeez
Re: FWI Calculator
« Reply #56 on: November 03, 2014, 06:39:56 AM »
Start by having a look under Help - Internet Options - File Options.
This will explain how the parse tags work plus give you code for a base page layout.
From there you can build using tags listed.
Also Under Graphs, Graph Maker. Play with these and upload the ones you want.
Yell if need more help.
Cheers
Jenny
Offline mkutche
    • GosportWx.com
Re: FWI Calculator
« Reply #57 on: November 03, 2014, 08:35:00 AM »
Still clueless on how to use the web stuff :(
Mike K.
Gosport, Indiana
Offline JennyLeez
Re: FWI Calculator
« Reply #58 on: November 04, 2014, 09:42:48 PM »
Hi again,
In brief you Set up Data – Make a web page – Parse web page – upload webpage.
Setup
I presume you have gone through and set up FWICalc following the Readme – Setting up Data. This can take a couple of days to get right especially the Cure Table. There is a bit of reading there but worth following it down. It took me a week before I was happy with what it was reporting.
It took me another week playing to sort out a web page. So yes it is a bit of work, but worth it.
Under FWI setup, bottom left.
If using Cumulus your Data File Type and Location is your realtime.txt. So select that and set the path. I will add a screenshot down bottom as readme is different.
FWICalc will auto update from there once a day.
Web Page
As far as the web page is concerned. It is up to you to build one.
In the readme, Under Internet Options – File Options the author has added an example which is a good starting point.
So open wxnewpage.php
Rename this to say wxfwicalc.php and save.
Slot the example in between:
<div id="main-copy">
<h1><?php langtrans('Fire Weather Index'); ?></h1>
<p>The following is FWI Data for the ^fwistation^.</p>
<p>Last Updated: ^fwitime^</p>
^fwitable^
</div><!-- end main-copy -->
Save this a second time and call it wxfwicalcT.php as the tags are parsed much the same as the Cumulus tags are in the standard version.
Parse web Page
Now we set up to parse the file.
In readme this is under Internet Options – File Options.
In FWICalculator click on Web Files.
Under Input files put the path to your wxfwicalcT.php something like
C:\cumulus\fwi\wxfwicalcT.php
On the other side under output files:
C:\cumulus\fwi\wxfwicalc.php
Click on Parse Now and that will replace the tags with your data.
Upload web page
Set up the FTP side of things as in the Readme – Internet Options – Dialup / FTP Setup.
Then,
Follow the readme to process this file and upload – Internet Options – FTP File List Select.
In this scenario under FTP File List Select you will have something like:
And under Server path:
public_html/wxfwicalc.php
To do a manual upload: Under Internet select Start FTP(Send all)
If FTP settings are correct, this will send this page up to your server.
Open it and see what you have.
I have not tested the above in the Saratoga template but I have no doubt it will stick out to the right :)
You can preen that back by unticking some of the columns – FWI Setup – tab Application Settings. On the left – Front page Chart Titles and under Show. Untick what you do not want.
Here is the above without any styling.
http://wairoa.net/weather/fwi/fwi_test.php
This gives you a brief outline as to how fwicalc works.
It is up to you to build your web page adding the fwi tags for parsing and displaying.
The full list of tags are in the readme. Get creative :)
Create some graphs for uploading. There is 2 full pages in the readme covering this. Then upload. Add links to these in your web page. Here are 2 examples of what can be done. This is a standalone page.
http://wairoa.net/weather/fwi/fire_index.php
This is the same page incorporated into the Saratoga template.
http://wairoaweather.net/wxfwi.php
Cheers and Good Luck
Jenny
« Last Edit: November 05, 2014, 04:44:02 PM by JennyLeez »
Offline pernaczy
    • Weather in Niesiolowice
Re: FWI Calculator
« Reply #59 on: May 27, 2015, 04:18:21 AM »
1. I'm new to this forum and I'm not an English native speaker so please, be tolerant.
2. Since November 2012 I'm running my Fine Offset WH 2080 weather station and my weather web page: http://www.pogoda-niesiolowice.kaszuby.pl/ .
Some time ago I decided to add the "Fire danger" warning to my web site and I started to use :CBI calculation" script: http://sandaysoft.com/forum/viewtopic.php?f=14&t=2789 (temporarily using ONLY CURRENT DATA for calculation). Result you can see on my web page, on the sidebar.
3. Now it's time to go further so I'd like to play with "FWI_calc". I found this topic and an "instruction" given by Jenny. It seems to be very clear and I hoped to go in an easy way.
4. Unfortunately "FWI_calc" is NOT running on my computer. Any time I try tu run it, an error message appears (see attachment). Has someone any idea why?
I'm running "Cumulus" software on "HP-5720" terminal with WindowsXP Service Pack OS 3 installed on 320GB HDD.
The day when I have learned anything is not the lost day.
Offline pernaczy
Re: FWI Calculator
« Reply #60 on: May 27, 2015, 10:22:59 AM »
Problem has been solved and I must say sorry for those starting (I hope) to think about my problem.  It seems to me that I wrote my previous post before starting to think. It was just enough to install "FWI_calc" NOT to the "C:\FWI\" folder (that is being proposed by installer by default), but to "C:\Program Files\FWI\" folder (my OS is WinXP).
Finally, an application is running and I hope to set is up shortly.
Piotr
Offline pernaczy
Re: FWI Calculator
« Reply #61 on: June 23, 2015, 02:54:49 AM »
Hi again,
It has almost been done: http://www.pogoda-niesiolowice.kaszuby.pl/firedangerrisk.php  :grin:
It was much less painful I expected it to be. Also I've learned a lot (following Polish proverb: Before, Iknew that they era playing. Now I know in wchat church).
Many, many thanks to Jenny ang Graeme. All the help I got from them was priceless.
Piotr
Offline WXH
    • Hoogeloon Weather
Re: FWI Calculator
« Reply #62 on: October 26, 2018, 03:18:30 PM »
Hello, link is not working anymore. Does some one have a new working link to FWICalc?
Davis Vantage Pro2 Plus & Weather Wizard III, Hoogeloon Weather
https://www.wxhoogeloon.nl/index.php
Offline JennyLeez
Re: FWI Calculator
« Reply #63 on: October 27, 2018, 04:43:04 AM »
Offline WXH
    • Hoogeloon Weather
Re: FWI Calculator
« Reply #64 on: October 27, 2018, 01:12:16 PM »
Thanks for the link :-)
I installed today this latest version. It is a pity that there will be no follow-up. I have this version (v.10.5.2.109) with Windows 7 Professional and works fine. But in the future with Windows 10 updates I'm not sure. Anyway that's not for now.
greetz Remie
Offline R_o_B
Re: FWI Calculator
« Reply #65 on: October 30, 2018, 09:25:43 AM »
...But in the future with Windows 10 updates I'm not sure.
Version 10.5.2.109 of the FWI Calc software works well (without problem) in Windows 10... ;)
R_o_B
eMail: weather@herray.net
Offline HansR
    • De Wilgen
Re: FWI Calculator
« Reply #66 on: September 22, 2019, 05:37:09 AM »
I created a standalone Fire Weather Index for the Cumulus environment.
The software can be downloaded here and pre-viewed here (Reports=>pwsFWI).
The science behind is can be found here.
Works only in the Cumulus environment!
« Last Edit: February 10, 2021, 01:38:32 AM by HansR »
Offline pekkie
    • Meteobrianza
Re: FWI Calculator
« Reply #67 on: February 09, 2021, 07:35:15 PM »
Good evening everyone. you want to ask for help. I have configured the fwicalc software and I have sent the data online the problem and not showing. how can i do to fix it? I as a weather software have cumulus. the site and this.
http://www.meteobrianza.net/wxcalc.php
« Last Edit: February 10, 2021, 07:27:53 AM by pekkie »
Offline the beteljuice
  • the beteljuice
    • test site
Re: FWI Calculator
« Reply #68 on: February 10, 2021, 03:25:52 AM »
On another forum you gave a slightly different link http://www.meteobrianza.net/wxcalcul.php
Which although an equally bad cut-n-paste paste page at least shows some "place holders" which have not been populated.
Offline pekkie
    • Meteobrianza
Re: FWI Calculator
« Reply #69 on: February 10, 2021, 07:32:16 AM »
Now I've changed it and that's okay. anyway i wanted to know if you want how to fix FwiCalc data. I've tried everything but it doesn't transfer my data online. Thanks in advance.
Offline TrugWX
  • Senior Meteorologist (ret), Australian Bureau of Meteorology
  • Truganina Weather
    • Truganina Weather
Re: FWI Calculator
« Reply #70 on: February 13, 2021, 06:33:25 PM »
From the Internet menu select Web / File Options. At the bottom of the page enter your website URL and check the box marked Post Data to FWICalc Website. That should be all that is needed.
Offline pekkie
    • Meteobrianza
Re: FWI Calculator
« Reply #71 on: February 18, 2021, 07:27:06 AM »
Thanks TrugWX. I did as you wrote me. The graphics were created but to upload them to the site I had to use Cumulusmx. With FWIcalc it does not load them.
Offline TrugWX
  • Truganina Weather
    • Truganina Weather
Re: FWI Calculator
« Reply #72 on: February 18, 2021, 08:49:53 AM »
Sending data to the FWICalc website only sends a small data file, it does not send graphics. The data contained in the file are displayed in a table and on a map against your location.
The graphics that are produced by FWICalc are for you to use on your own website using either the inbuilt FTP option or another FTP client (as I do).
Offline pekkie
    • Meteobrianza
Re: FWI Calculator
« Reply #73 on: February 18, 2021, 10:01:16 AM »
ah ok now I understand. what client do you use? I can load them with cumulusmx
http://meteobrianza.net/fwi/fmi.jpg
Offline TrugWX
  • Truganina Weather
    • Truganina Weather
Re: FWI Calculator
« Reply #74 on: February 18, 2021, 04:00:30 PM »
I use Fling File Transfer to upload numerous graphics at regular intervals, including those produced by FWICalc.
I have checked the FWICalc website for your data and I cannot see it yet - it may take some time for it to appear. The table of stations is at https://www.arthurspass.com/fwicalc/fwi_table.php and the world map is at https://www.arthurspass.com/fwicalc/fwi_world.php.
