Weather Software => Cumulus => Topic started by: meteolarissa on August 04, 2020, 08:46:10 AM
Good evening to all. I would like to ask if any of the guys have worked this software with the new 2019 model station.
I also attach the link so you can have an accurate picture of the model.
Someone I know has a problem with cumulus connections to this station and I'm worried because I want to buy this station too.
https://www.froggit.de/product_info.php?language=de&info=p316_wh1080-se-profi-funk-wetterstation-solar-touchscreen-usb--neuer-aussenmast-.html
[ You are not allowed to view attachments ] [ You are not allowed to view attachments ]
Vassilis
Larisa-Greece
That may look like the other popular Fine Offset clones but it isn't the same. Take a close look at the anemometer part. It is totally different. It is not compatible with the GW1000 / DP1500. I'm not saying it isn't a Fine Offset clone, rather that it is actually a revival of an older generation, which I don't recommend.
I recommend instead as a basic station the Froggit WH3000 SE abd then add to it the DP1500 gateway device. Then it will work with Cumulus MX.
https://www.froggit.de/product_info.php?info=p287_froggit-wh3000-se-wifi-internet-app-weather-station-ecowitt-server.html
If you want a nicer display and more features and extra sensor expandability then I recommend the HP1000 SE PRO (again also add the DP1500).
https://www.froggit.de/product_info.php?info=p436_hp1000se-pro-wi-fi-internet-wireless-weather-station.html
If you don't need a display then just get the DP1500 kit with outdoor sensor array.
https://www.froggit.de/product_info.php?info=p465_dp1500-wi-fi-weather-server-usb-dongle---wh3000se-all-in-one-outdoor-sensor.html
Add on - just the DP1500 (required for Cumulus MX compatibility)
https://www.froggit.de/product_info.php?info=p410_dp1500-wi-fi-weather-server-usb-dongle.html
