Author Topic: Weather underground offline 5 monts  (Read 2278 times)
Offline Frannor
« on: June 29, 2022, 05:08:40 PM »
Hi All.
My station is offline for the last 5 monts.
I have deleted my account and registered it a few times.
Changed e mail address .
I also contacted weather underground and have had no reply .
Can anybody give me some advice.
Also I am registered with Weathercloud and have no problems at all.
Sorry this is my first post to this form
Thanks Frannor
Offline Daali
  • weather n00b
    • The weather in Jefferson, GA
Re: Weather underground offline 5 monts
« Reply #1 on: June 29, 2022, 05:25:33 PM »
I do not have any advice other than to just forget about wunderground.  They've effectively have killed the PWS format.  Some have no issues at all, but most (like us) are having more and more difficulty.  I still send data to WU. But when it fails (often), I stopped caring.
Offline Frannor
« Reply #2 on: June 29, 2022, 05:53:55 PM »
Hi Diaali.
Thank you for your reply.
I thought I was the only one with the problem thanks for your input.When I signed up for the first time it worked perfectly and I never had a glitch.
Thanks Frannor.
Offline CamarilloWX
  • CamarilloWX
    • Camarillo Weather
« Reply #3 on: June 29, 2022, 05:54:00 PM »
Hi Frannor, welcome to the forum.  Have you confirmed your station ID and key in whatever you are using to upload?  They must match what you have listed at Weather Underground under "Member Settings" - "Manage Devices".  The password used by your software is no longer the Weather Underground password you use to log in and is now the key listed under "Manage Devices".  Weather Underground support seems to be gone.  Years ago they would respond to emails but that seems to have stopped a while ago.
Eric
Offline Frannor
« Reply #4 on: June 29, 2022, 06:39:20 PM »
Hi Camarillo.
I have tried what you have suggested and still no success.
The porblem started after we moved in to summer time
Thanks Frannor
Offline Frannor
« Reply #5 on: July 24, 2022, 03:39:04 PM »
Hi All.
Would anybody be willing to test my PWS
IKILMA83 to see if is online.I have deleted and reset my station and did the same I weather underground.This is a new I'd setup 23 July 22
I can see weathercloud online perfect.
Thanks Frannor
Offline PaulMy
« Reply #6 on: July 24, 2022, 04:08:53 PM »
Station IKILMA83 shows Page Nor Found.
Searching for KILMA and change to other stations shows https://www.wunderground.com/weather/gb/kilmarnock
Enjoy,
Offline Frannor
« Reply #7 on: July 24, 2022, 04:17:35 PM »
Thanks Paul for your help.
I will give it a few more days because they say it could up to two days to go online I don't give it much hope
Offline JECO
« Reply #8 on: July 25, 2022, 10:07:21 AM »
This is why I switched to PWS weather.
Offline Jasiu
    • LexMAWeather
« Reply #9 on: July 25, 2022, 10:59:38 AM »
I still send to WU, but PWS is definitely more reliable. It's what I use on my "nearby weather stations" web page.
https://lexmaweather.info/pws.php
Offline JECO
« Reply #10 on: July 25, 2022, 11:41:09 AM »
I agree Jasiu. Nice site you have. My only complaint is the 30 minute delay in postings that are required when using a Vantage Pro 2 station.
Offline Jasiu
    • LexMAWeather
« Reply #11 on: July 25, 2022, 11:55:47 AM »
Is that more a matter of the software you are using? I have a VP2 connected to a Meteobridge and update to PWS once a minute.
Thanks for the compliment!  :grin:
Offline JECO
« Reply #12 on: July 25, 2022, 12:39:09 PM »
Yes, I use Weatherlink. That is the reason for the delay. I am squeamish about using different software for fear of messing up my records. Wonder if I can use both Weatherlink and Meteobridge?
Offline PaulMy
« Reply #13 on: July 25, 2022, 01:47:53 PM »
@Frannor,
What method are you using to upload to WU?
Enjoy,
Offline PaulMy
« Reply #14 on: July 25, 2022, 01:56:53 PM »
@JECO,
How do you use Weatherlink to upload to PWSWeather?
Enjoy,
Offline Frannor
« Reply #15 on: July 25, 2022, 03:19:41 PM »
I am using my Samsung a52s phone where I type in http://192.168.1.1 then i enter all the required  details and  my weather station a Bresser 5 in one pws
Offline JECO
« Reply #16 on: July 25, 2022, 03:41:57 PM »
PaulMy, I upload my weather station to the Davis Weatherlink site. PWS Weather has instructions on how to link with Weatherlink. They make it pretty simple
Offline PaulMy
« Reply #17 on: July 25, 2022, 03:55:39 PM »
@Frannor,
I am not familiar with the direct http or get update as I use both CumulusMX and WiFiLogger to update my WU accounts, but if you use http://192.168.0.1 isn't that just a local IP and not a remote like WU?
Enjoy,
Offline PaulMy
« Reply #18 on: July 25, 2022, 04:13:50 PM »
@JECO,
I guess I need to become more familiar with such things :oops:  I like and have been using PWS Weather for over 13 years https://www.pwsweather.com/station/pws/komoka  and https://www.pwsweather.com/station/pws/komoka2 and didn't know you can use Weatherlink to update and instead have been using Cumulus and WiFiLogger.  There is no option on my Weatherlink.com Upload settings for PWS Weather.  And the PWS Weather site site says:
Davis does not currently support sending data to PWSweather.com with any of their WeatherLink products. Please let Davis know you want this capability by contacting their support at support@davisnet.com. Some software which supports sending data to PWSweather.com can be used with a variety of hardware. A list is available in the above section “How to post data to PWSweather.”
Enjoy,
Offline JECO
« Reply #19 on: July 25, 2022, 04:57:36 PM »
Paul, if you go to the PWS site and click on FAQs in the upper right corner, scroll to PPWS setup and then "how to setup a WeatherlinkIP device, you can read how to do it.
Hope this helps. As I have said, the disadvantage is that the uploads are every 30 minutes. I would prefer every one or two minutes, but that is not possible apparently.
Offline PaulMy
« Reply #20 on: July 25, 2022, 05:16:38 PM »
@jeco,
Still haven't learned  ](*,) :oops:
If I click on WeatherlinkIP I get as per attached
Enjoy,
Offline WheatonRon
    • WUnderground
« Reply #21 on: July 25, 2022, 05:53:20 PM »
@jeco,
Enjoy,
I hope there is a workaround but per the page Paulmy posted, not possible.
Offline JECO
« Reply #22 on: July 25, 2022, 06:00:47 PM »
Paul, there is a way. Let me think about it and then report back.
Offline WheatonRon
    • WUnderground
« Reply #23 on: July 27, 2022, 05:03:43 PM »
Pws weather is posting data from Madis, aka CWOP. So if I go to my dashboard (map) on pws weather, I see my station that uploads to pws weather directly and I can see my other station that posts to pws weather directly plus my 3 stations that post to Madis which includes 2 of my stations that post directly to pws weather. Talk about overkill!
What is interesting though, the rainfall pws weather is “pulling” from Madis is wrong!
« Last Edit: July 27, 2022, 05:21:36 PM by WheatonRon »
