I modified my AS3935 logging and graphing script to also log the new server-generated alert data to a separate CSV text file. I also wrote scripts to display strike rate, distance, and average bearing.
Since only one PHP script can be called from the Actions settings, the script now discriminates if it is called from the AS3935 or a Server Alert and logs the data to the correct file.
I'm going to test for a time before posting the updated scripts.
The new graphs may be seen here:
http://projectmf.homelinux.com/alert_stats.htmlRegards,
Don
WD9DMP
