Author Topic: WS 2315 Battery Life  (Read 4471 times)
Offline Kevin Walls
    • Willow Springs NC
« on: February 13, 2009, 03:12:53 PM »
I am having continuing problems with Battery Life on my Remote sensor that is in wireless mode.
Life is approx 6 weeks.
 :sad: I have to climb a ladder, disassemble the Solar radiation shield to get at the sensor and replace the batteries each time.
All I have gotten from LaCrosse is :
 "Batteries are our #1 warranty issue. Please be sure you are using name brand Alkaline batteries dated 6 years in advance or testing to at least 1.48 on a voltmeter"
My last old set of removed Batteries showed 1.71 and 1.65 V on my voltmeter.  :?
Has anyone solved this problem successfully ?  ](*,)
Can I wire a transformer to replace the batteries ?
Kevin
CW7607    K8INCWIL1
CW7607    K8INCWIL1
Willow Spring, NC 27592   Davis VantagePro2 Wireless
Offline wuhu_software
    • WUHU Software Yahoo Group
Re: WS 2315 Battery Life
« Reply #1 on: February 13, 2009, 06:12:06 PM »
If you google around, you can find instructions for replacing the AAs with a couple of dowels, screws, and connect them up to a wall wart that outputs 3VDC.
6 weeks seems very low...
I am wondering if the console is losing 'sync' with the remote due to noise or some other issue.
The next time it dies, try holding down the + key on console until it beeps twice. It will then search for the remote sensor.
If it comes back, my guess is that the remote is a tad too far from the console.
