Author Topic: Why no USB cable?  (Read 8927 times)
Offline rv55
Why no USB cable?
« on: February 01, 2008, 01:47:05 PM »
I just bought a 2308 ws. my laptop does not have a serial port, why does LaCrosse still use a serial cable and not USB? Best way around this? Thanks
Offline jwwd
    • Weather at Silkeborg, Denmark
Re: Why no USB cable?
« Reply #1 on: February 01, 2008, 02:08:05 PM »
Hi
I have a Lacrosse WS-2305 station - and I have connected it to my dedicated HP laptop thru a Serial to USB connector.
Search for USB to RS232 in Google or Ebay and you will come up with lots of hits.
I suggest you buy a good quality Serial-to-USB connector.
Best regards,
Henrik
Davis Vantage Pro2 w/FARS & solarsensor. Boltek LD-250 Lightningdetector
Offline KB3NRY
« Reply #2 on: April 20, 2008, 12:56:53 AM »
Can you post the specific cable, brand and model number, of the one you have.  Not every USB to Serial cable will work.  I have one that works with 2 other devices, but not with Heavy Weather.  I'd like to find one that I know will work for me.  Thanks.
Offline jwwd
« Reply #3 on: April 20, 2008, 02:04:42 AM »
Hi
The one I use I have bought here in Denmark and it works very well.
Here is the link to: http://www.thansen.dk/product.asp?c=1751321472&n=496908102&pn=572895931
It costs about 31 us dollar. (Remember the dollar rate is very low now)
Hope that helps.
Best regards,
Henrik
Offline mi77915
« Reply #4 on: May 23, 2009, 07:39:57 PM »
I have the same problem. My desktop computer does not have a serial port. I hae a radio Shack here in town, do they carry a good quality serial to USB connector?
Tom
« Reply #5 on: May 23, 2009, 11:33:25 PM »
http://www.radioshack.com/search/index.jsp?kwCatId=&kw=usb%20serial&origkw=usb%20serial&sr=1  But for a little more than a 1/10 of the price you can get one from dealextreme.com
Offline Weather Display
« Reply #6 on: May 23, 2009, 11:54:16 PM »
Prolific type chipsets, Iogear, or Keyspan chipsets seem to be the best adaptor types to use with the lacrosse stations (which do not use standard serial communications)
Brian
info@weather-display.com
Offline wuhu_software
    • WUHU Software Yahoo Group
« Reply #7 on: May 25, 2009, 08:36:22 AM »
The WS-23XX series does use normal serial character communications but does rely on DTR and RTS to be functional. Many of the cheap USB to serial adapter do not support the hardware handshaking lines.
The WS-36XX series does use a home brew communication scheme using only the handshaking lines.
My recommendation is to go with the IOGear:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812107906
It is pretty rock solid and you never see OS kernel level crashes because of a poorly written Windows driver.
Offline kanewolf
    • Weather at Chez Baron
« Reply #8 on: May 25, 2009, 10:49:43 AM »
I have used the IOGEAR with no issues on both Windows and Linux (even NSLU2) for my Davis unit.
