Airlink
(1/2) > >>
drew1021:
Iím considering adding the Airlink to my VP2 suite and have a few questions for those who own one.
First, are there any replacement parts available such as temp/hum sensor, or is it integrated onto the pc board? Also Iím concerned about the internal fan reliability over time, is the fan available and user replaceable? Second, has anyone rigged up a solar charging system to power the device. Specs show the DC input to be 5Vdc. Davis offers a solar panel with battery that is rated at 6Vdc output, would this work?
Thanks for your assistance.
BTW tech support not any help.
mcrossley:
The T/H sensor is integral - I did not see a separate sensor when I have had it apart - it may even be integral to the sensor unit.
The fan is integral to the sensor unit (as all the consumer grade sensors I have seen are).
Mine has been installed outside since Nov. 2020, and - touch wood - no issues so far.
Sorry, but no idea on the solar panel.
drew1021:
--- Quote from: mcrossley on February 08, 2022, 10:30:57 AM ---The T/H sensor is integral - I did not see a separate sensor when I have had it apart - it may even be integral to the sensor unit.
--- End quote ---
I suspected that the sensor and fan were integrated onto the main pcb. Thatís a shame. So sounds like there currently are no replacement parts available. Iím not going to purchase it knowing that it is most likely disposable. I typically replace my temp/hum sensor on my vp2 annually.
mcrossley:
Its not that they are on the circuit board, they are integral to the Plantower AQ sensor module itself, which is then part of the main board. I do not know of a consumer grade unit that does not use a integral third party sensor module (Plantower/Sensirion/Nova/whatever)
drew1021:
Iím curious if Davis will have flat rate repair/pm on the device.
[#] Next page
