Author Topic: NOAA WEATHER RADIO  (Read 140406 times)
Offline gwwilk
  • Southeast Lincoln Weather
Re: NOAA WEATHER RADIO
« Reply #1150 on: February 22, 2020, 11:14:59 AM »
I abandoned Chrome for the Chrome-based Brave browser last Fall.  Brave allows a granular approach to unblocking sites that is essential for accessing/displaying some or portions of some web sites.  I'm not interested in their 'Rewards', but the browser has served me very well.
Regards, Jerry Wilkins
gwwilk@gmail.com
« Reply #1151 on: February 22, 2020, 11:25:01 AM »
I can confirm there is an issue with Chrome. I loaded my WxRadio page on Chrome on my desktop just now and it worked fine. That was with version 79.0.3945.130. I then updated Chrome to 80.0.3987.116 and now I get 'Failed to Load Audio Stream'.
Steve
I think the latest Chrome 80.0.3987.116 now militantly blocks http content (radio streams) from an https page.  Firefox allows it.
Because wxradio.dyndns.org (the Icecast server running most of the streams) and most privately-offered streams are http only, this is going to be a problem with Chrome unless someone finds a way around it .. switching to a browser that works (or switching noaaweatherradio.org to not redirect to https) is another possible solution short-term.
Offline n2jtx
    • My Website
« Reply #1152 on: March 05, 2020, 11:14:47 AM »
An option for SSL is to go with the free Let's Encrypt service (https://letsencrypt.org/). There are instructions on setting it up at https://mediarealm.com.au/articles/icecast-https-ssl-setup-lets-encrypt/. I use it myself but not with Icecast. The only downside is the certificate needs to be renewed every 90 days. There is an automated routine (certbot) to do it but it requires some configuration work.
Offline 92merc
  • BismarckWeather.net
  • Moderator
« Reply #1153 on: March 05, 2020, 11:41:59 AM »
Unfortunately, it's a bit more complicated than just getting a cert when it comes to Icecast.
If the Icecast server wasn't built with OpenSSL pre-compiled into the installer, Crushed Box Software would need to re-install it.  So that means either downtime.  Or they'd have to bring up a new server with that already done.  Plus they'd have the work of re-doing the cert every three months.  So more work than they are doing now.
There are other possibilities like using a reverse proxy to serve up the stream.  Not sure if they are interested in doing that.  At least with that option, you can then use Certbot to automatically re-new the cert.  Certbox can work with Icecast from what I've read.  But again, not an easy task.
Offline Cutty Sark Sailor
  • Moderator
« Reply #1154 on: May 08, 2020, 10:06:45 AM »
Enough is enough.... cut the hassle with NWR SSL Streams
Knowing Chrome, Goiogle, et.al. plan even more drastic 'restrictions' on mixed content, A couple of moths ago, Took this action.  Do as you will.
NO Hassle, no other charges, 32KB, stats, etc, and most importantly, SSL https://getstreamhosting.com/ssl-radio
Mike
« Last Edit: May 08, 2020, 10:09:01 AM by Cutty Sark Sailor »
« Reply #1155 on: May 08, 2020, 01:26:07 PM »
Ok.. I submitted change requests to swap my direct streams to the two SSL endpoints at getstreamhosting.  $10 is a small price to pay.  Thanks for the nudge, Cutty!
Offline ed2kayak
  • Ed
    • Cumberland Valley Weather
« Reply #1156 on: May 09, 2020, 08:33:33 AM »
Mike
Cutty, it says works with encoder - Icecast2 or Shoutcast v1.
I use BroadWave, will it work with that?
Ed
Ed
  • Moderator
« Reply #1157 on: May 09, 2020, 09:39:52 AM »
Mike
Ed
No... Broadwave is't just an encoder, it is the server.
You'll want to use the IceCaset option on the GetStream,, it's the freebie.
An encoder simply codes the audio to mp3, and connects it to the server.
You cana leave broadwave as it is, as an alternate, and:download BUTT, for example, and also install it, take the same audio in souyrcee Broadwave uses, and set up the stream.. You can run both at same time. One advantage to sending mp3 to the icecast:  It does all the heavy lifting.  Broadwave uses more network and computer resources if multiple folks connect to the stream
Folks hitting the Icecast keep the load there, not on your network.
See:  https://noaaweatherradio.org/howto.html for encodes we have on site download,... there are others available...most want some money, however...heh
there are some 'quickly' produced setup hints, e.g. BUTT also e.g. https://noaaweatherradio.org/Encoders/BUTT/QuickSetButt-wxradio.dyndns.org.pdf
Offline mikev
« Reply #1158 on: May 10, 2020, 09:36:41 AM »
Mike... I've had an HTTPS version of my stream (KHB36 alternate) available and in the list for a while. If you want to remove the HTTP version, that's fine. I'll submit the form to get my QRA report going on the HTTPS stream.
« Reply #1159 on: May 12, 2020, 01:17:34 AM »
Please pardon my confusion, but  does switching to getstreamhosting mean I can't continue to be in the NOAA Weather Radio Network?
Offline 92merc
  • Moderator
« Reply #1160 on: May 12, 2020, 08:48:00 AM »
No, you can be a part of the NOAAWeatherRadio.org site.  You'll just need to submit your new link so they can update their records.
Offline lddaly
« Reply #1161 on: May 26, 2020, 11:07:38 AM »
Mike
Thanks, Mike and Ken. I moved over the KEC56 stream last week and everything has been working fine. This was the last remaining non-secure element on my website. The additional stream usage metrics from this service are also nice to have.
Offline MchWxEnthusiast
  • That Guy
  • Nothing Much
« Reply #1162 on: May 26, 2020, 02:59:44 PM »
what's with the lock icons on some streams?
Weather Radio Freq: 162.475 MHz
Weather Radio Loc:  Plainwell, MI
Transmitter Call Sign: WWF34
Streaming Status: NN
« Reply #1163 on: May 26, 2020, 03:05:56 PM »
Those indicate a HTTPS (SSL) radio stream.  With recent updates to browsers, if you access a site using https:, then all the media (images, streams) must also be https: to be used.
The padlock (like the padlock shown on your browser) simply shows those streams that can be used with both http and https access and are the only ones that can be used when the page is loaded https.
Offline Otis
  • (aka Paul)
    • Lake Huron Weather
« Reply #1164 on: June 30, 2020, 06:13:16 AM »
Just an FYI about this stream.
PUBLIC INFORMATION STATEMENT
NATIONAL WEATHER SERVICE GAYLORD MI
412 AM EDT TUE JUN 30 2020
...NOAA WEATHER RADIO OUTAGE...
DUE TO SCHEDULED MAINTENANCE, NOAA WEATHER RADIO STATION WNG-572,
BROADCASTING FROM NEAR GOOD HART, MICHIGAN, ON A FREQUENCY OF
162.475 MHZ, WILL BE OFF THE AIR INTERMITTENTLY TODAY, JUNE 30TH,
FROM 8 AM TO 8 PM. WE APOLOGIZE FOR THE INCONVENIENCE.
CW3699
  • That Guy
  • Nothing Much
« Reply #1165 on: July 01, 2020, 11:29:29 PM »
kinda irrelevant to what you guys are talking about but it would be nice to have streams from the upper peninsula of Michigan and also northern Minnesota.
Offline Otis
  • (aka Paul)
« Reply #1166 on: July 02, 2020, 06:21:44 AM »
Just requires somebody to stream them, yes would be nice to have them.
CW3699
Offline gwwilk
« Reply #1167 on: October 14, 2020, 07:47:31 AM »
The Lincoln, NE WXM20 transmitter has malfunctioned.  The stream from both of my feeds is almost all noise at this point, so it provides no useful information.  I believe that this is the same problem that afflicted the Omaha transmitter recently.  Who should I contact regarding this?
« Last Edit: October 14, 2020, 07:49:21 AM by gwwilk »
gwwilk@gmail.com
Offline tmabell
    • Mishawaka Weather
« Reply #1168 on: October 14, 2020, 07:51:46 AM »
I'd try the WCM at Omaha.  Email or PM for his contact.
Offline gwwilk
« Reply #1169 on: October 14, 2020, 07:54:40 AM »
I would say that they have their hands full from the looks of this map!  No need to report what they're already aware of...
Perforce, here's the plan:
« Last Edit: October 14, 2020, 08:06:59 AM by gwwilk »
gwwilk@gmail.com
Offline NWROrg Team
  • Save A Life
  • Moderator
« Reply #1170 on: October 14, 2020, 08:21:17 AM »
Gerry, contact the Omaha/Valley NE WFO (OAX) directly,...    nws.omaha@noaa.gov they're aware of the issue, but may be able to give you an update....
Actually, the quickest way, sometimes, is to contact the 'owning' WFO directly... they may not even be aware of an issue if you've caught it quickly, and many issues can be corrected fairly rapidly.  You can ALWAYS report an outage or issue at
https://www.weather.gov/NWR/nwr_outage_report but it usually takes MUCH longer than checking with local first.
Offline gwwilk
« Reply #1171 on: October 14, 2020, 10:16:53 AM »
I've been wrestling with Win10 Updates on over 10 affected computers, but I can now see the light at the end of that tunnel.
I appreciate the suggestions, and I have sent a query re estimated WXM20 downtime to the OAX NWS office.  Thanks!
gwwilk@gmail.com
Offline gwwilk
« Reply #1172 on: October 14, 2020, 06:58:23 PM »
This is the reply I received from NWS Omaha:
Hi Jerry.
The issue is due to a Verizon line at the transmitter. They inform us they continue to troubleshoot the Verizon issues. We suggest having multiple ways to receive weather information like weather apps on a smart phone or via internet/TV sources.
Our apologies.
NWS Omaha
I hated being just another burr under their saddle, but the information is useful.
gwwilk@gmail.com
Offline NWROrg Team
  • Save A Life
  • Moderator
« Reply #1173 on: November 12, 2020, 08:16:23 PM »
Watch This Topic...
For important information, and updated service for HTTPS (SSL/TLS) streaming server solution.
Coming Very Soon!
Offline NWROrg Team
  • Save A Life
  • Moderator
« Reply #1174 on: November 14, 2020, 01:57:06 PM »
