OK so I have 3 gateways now, a GW1000 and GW1100 both of which are working connected to my mesh system at 2.4ghz and currently working fine, the GW2000 is connected to my same mesh network at 2.4ghz and I can ping it with about a 5ms response however it refuses to talk to anything which tries to open a TCP port either CumulusMX or my own PHP script which gets the data via the same API as both Weather Display or CumulusMX. I have no issue with anything else on my network at all, all phones,TVs tablets and my Weather Display using wifi to talk to the GW1100.
Just to add a power cycle has brought it back working again.
Wifi issues are sometimes a real faultfinding nightmare.
Once upon a time I had a Zyxel adsl-wifi gateway and a Canon pixma inkjet connected to the wifi. The printer worked perfectly for days and weeks, until someone tried to print something from ipad. The result was half of the page printed, rest of it was white, and the printer dropped off from the wifi. All other devices on the network worked just fine despite the error, but the printer just could not get a connection anymore, no matter what you tried. The only way to get the printer back online was to reboot the zyxel itself. This repeatable issue was repaired after a firmware update from zyxel.
Mesh wifi also does have its own caveats. Sometimes the mesh systems try to control how the clients connect and to which accesspoint. Usually this is done by just kicking the client out from one ap so that it would connect to the another one. Usually the user doen not even notice, or there is only a small hiccup. But somethimes the clients are ”sticky” and for some reason do not want to change to the another ap. This may result headbanging, where the ap repeatedly kicks the device out, and it just keeps reconnecting to the same one. This issue can sometimes also be seen with band steering feature if 2.4Ghz and 5 Ghz ssid is the same.
A few years ago when completing my 5 day CWNA certification, our instructor said, ”It is surprising how well the wifi usually works despite the fact how horrible its design basics and backward compatibility features are”.
However just to be clear, I’m not saying that it must be a wifi issue you are experiencing. I’m just saying, that it is very hard to exclude that possibility except by connecting the GW2000 via wired lan.
Sami
