Author Topic: GW1003, how can i get the heater cable by USB?  (Read 7902 times)
Offline Gyvate
Re: GW1003, how can i get the heater cable by USB?
« Reply #75 on: January 16, 2021, 06:57:57 AM »
now one can see the effect of the heater over a whole days below 0°C.
and over one week - it's clearly visible when the heating was switched on.
Usually the difference in the sensor values is 0.1C-0.4° C where the WH31-EP in the Metoshield Pro is the most realistic..
« Last Edit: January 17, 2021, 03:32:53 AM by Gyvate »
Offline Mandrake
« Reply #76 on: January 16, 2021, 07:35:28 AM »
Thanks Gyvate, I guess it was inevitable that the heater (low power as it is) would essentially have an impact on the temperature sensor readings being that the sensor is so close.
I have to say though that the need for heating needs to be looked at closely as so far I have avoided any problems with wind readings without using said heater plate (mine being a pre-production model does not have the cable installed). I am though in Southern England with a kind climate that so far has not thrown up a combination of wet/freezing that has upset the ultrasonic emitters to date.
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline Gyvate
« Reply #77 on: January 16, 2021, 09:25:27 AM »
Not that I mind much.
I have my reference sensor (WH31-EP in my Meteoshield).
And the wind measurements haven't been an issue either (until switching on the heater - longer I cannot tell).
However, the solar panel and the solar sensor need to be functional, what they aren't when covered with snow or ice.
I might take a closer look into the idea of an automated brush inspired by Quagmire's post.
« Last Edit: January 16, 2021, 09:27:06 AM by Gyvate »
Offline wardie
« Reply #78 on: January 25, 2021, 07:36:57 AM »
Here's a couple of shots I took yesterday when we had 2-3 inches of snow here plus temps moving between 1C to -5C. Photos at an angle now as I've managed to move my WS80 mount to a higher position (actually similar to WS68) but found a way to get the heater cable to it. The heater is plugged in and switched on for these photos (I'm assuming it was in use, not measured power after initial testing when it drew 12W). From looking at it it seems to be working.
As an aside, if I'm taking the wind data from WS80 into a GW1000, but taking the temp data from a WH32 (at ground level) into same GW1000, does anyone know how I can still access the temp data from WS80 to check out the above heating effect for example? Or is that impossible and I just have to temporarily disable the WH32 in any given console to find out.
Froggit HP1000SE Pro-C console (HP2551-C)
Froggit HP1000SE Pro ultrasonic multi sensor with Ecowitt EC0002 heater (WS80)
Ecowitt Anemometer 5-in-1 array (WS68)
Froggit DP80 rain gauge (WH40) with spikes
Froggit indoor temp/humidity/pressure (WH32B)
Froggit DP50 Internal temp/humidity x2 (WH31)
Ecowitt Outdoor temp/humidity & RS-00001 shield (WH32)
Froggit DP200 PM2.5 outdoor (WH41)
Ecowitt indoor CO2 PM2.5 PM10 (WH45)
Froggit DP100 soil moisture (WH51)
Froggit DP60 Lightning detector (WH57)
Froggit DP1500 server dongle (GW1000A) x2
Raspberry Pi 4 / WeeWx-GW1000 API interface
WU: IKNEBW2
Offline olicat
  • GWxx00, HPx5x1C, WN1900C, WN1980C & WS3xx0C
    • FOSHKplugin
« Reply #79 on: January 25, 2021, 07:46:58 AM »
Hi!
As far as I know this is impossible.
The WH32 is favored by the station - other WS80 values are certainly transferred - but ignored by the station.
So you have to disable the WH32 to see the temperature values of the WS80.
Alternatively: use a GW1000 and disable the WH32 there.
Oliver
Offline Gyvate
« Reply #80 on: January 25, 2021, 09:00:39 AM »
Only if you have more than one console and make respective assignments - or have some hardware+software which read directly from the sensor (which would then factually be a console) and reconcile it e.g. in weewx.
Another way which I use is:
I have a WH32 and a WH31 put together in one shield - so I can take the WH31 signal as the WH32 (they produce exactly the same readings - checked this over 1/2 year) - then it works with one GW1000 - and I display them together in one chart.
« Last Edit: January 25, 2021, 09:04:19 AM by Gyvate »
Offline wardie
« Reply #81 on: January 25, 2021, 05:18:54 PM »
Hi!
Oliver
Yes thanks I did a quick test of that approach by ignoring the WH32 on my HP2551C (mainly because I use that for display only, it’s the GW1000s/Pi that record the data for me and upload to web/community services, aside from Ecowitt.net).
In the few hours I tested it, I believe the heater was on given the temp here is just <0C and dark. I noticed that the temperature of the WS80 reported was consistently about 0.8C ish higher than my WH32. And that’s despite my WH32 is now at 1m level in the Ecowitt shield (I know not great) so mounted in shade under a tree, whereas the WS80 is almost exactly 10m right at the top of the roof now exposed.
WU: IKNEBW2
Offline superpat
Re: GW1003, heater plug / socket
« Reply #82 on: February 08, 2021, 09:14:00 AM »
HI
 My Ecowiit  Gw1003 has finally been shipped and is winging its way to the UK as I write.
I have one job to do before it arrives on the 16th Feb, and that is to sort out the WS80 heater cable.  I have lots of 12v dc o/p AC adaptors here so I was not going to pay another  load of dosh for the Ecowitt one. (The adaptor will be in the house, just a 12v twin cable to the heater outside, so I don't need a weather proof adaptor.)
I have read all the replies in this thread, and  cannot find a definitive answer to the info I am after. There are several types mooted, but I am unclear what is the answer.
I need a cable mounted 2 pin socket, to connect to the Ecowitt  plug on the end of the short heater cable.    Please, has anyone got a definitive type / part number for this connector?    (That not only fits the pins but will screw together and be water proof?)
I know I can wait till my WS80 is delivered and research it myself, but if I have to get a connector from China, it will take another month. With the present weather conditions in the UK, the heater need to be connected and working from the start.   I know I can make a temporary bodge till I get a proper connector, but I was hoping to have all the bits ready for when the WS arrives, and not have to keep running up and down a ladder.
thanks in advance
regards
Patrick
Offline wardie
« Reply #83 on: February 08, 2021, 06:14:07 PM »
HI
thanks in advance
regards
Patrick
I don’t recall seeing any part markings. Apart from info in post 62 here’s another pic if that helps?
WU: IKNEBW2
Offline superpat
« Reply #84 on: February 09, 2021, 05:17:52 AM »
Hi
Thanks for reply.
 My problem, is that although several people here  have measured the supplied connector and published the numbers (above). the Chinese vendors of  similar connectors do not give reliable sizes of their offerings. One Ebay vendor gives the  maximum dimension of the coupling nut, but not the thread.
I am guessing it is a M12 fine, but some dimensioned drawings I have seen for other vendors state M13 or M15 !!  Pin diameters appear to be another minefield
I will see if Ecowitt can provide any info.    Otherwise I think I will bodge it.  I can find a couple of suitable pins in my junk box,  I'll crimp them to a two core cable, ram the pins into the end of the Ecowitt connector, and secure and waterproof the joint  with a piece of heat shrink tubing. If the joint with sleeving will fit back inside the tube from the WS80, it should be out of the weather.
As a previous poster said, it is not advisable to lop the supplied plug off the WS80 feed cable until the warranty has expired, in case I need to return it for repair / replacement.
cheers P
Offline Quagmire
« Reply #85 on: February 10, 2021, 10:25:23 AM »
That's exactly what I did with mine; couldn't be arsed to find the proper connector. Been workin' fine ever since.
Offline plectron25
« Reply #86 on: February 14, 2021, 05:37:20 PM »
I have seen that type of weatherproof DC connector used on various LED outdoor landscape lights and heavy duty holiday lights.
With the snow covering the solar panel in the winter, and snow not measured (until it becomes melted water) by the rain gauge I hope someone comes up with a handy breakout cable add-on that can use a suitably sized 12vdc power supply to also melt snow on the rain gauge and provide the 3vdc backup power to the wind gauge and perhaps even 1.5vdc for the rain gauge transmitter.  I do admit that changing the batteries every year or two does have the benefit of encouraging me to go up on the roof to clean out leaves and wipe off bird offerings.
I look forward to trying out a WS80 based system to compare to the WeatherFlow Tempest that I have been running for a while now.
Perhaps among these listings the proper connector can be found?
https://www.amazon.com/dp/B089W9L4SX/
https://www.amazon.com/dp/B01LCV8DXQ/
https://www.cicig.co/product/i6gbgpx
« Last Edit: February 14, 2021, 08:41:53 PM by plectron25 »
Offline Jeje2
« Reply #87 on: October 07, 2021, 10:01:32 AM »
If the heater is connected - will it always heat?
Or is there in the WS80 unit a heating switch based on temperature reading?
(Or do I need to set up a solution where the heater adapter is powerd based on outside temperature?)
Ecowitt:
  • GW1102 Wi-Fi Weather Station with Solar Powered Wireless Anemometer, UV & Light Sensor, Self-Emptying Rain Collector
    • GW1100 Ecowitt Wireless Weather Station Gateway
    • WS68 Wireless Solar Powered Anemometer with Light & UV Sensor
    • WH40 Wireless Self-Emptying Rain Collector Rainfall Sensor
    • Outdoor Temperature and Humidity Sensor
  • WH31 Multi-Channel Temperature and humidity Sensor (8 pcs)
  • WH51 Wireless Soil Moisture Sensor
  • WH45 Indoor CO2 PM2.5 PM10 Temperature and Humidity 5-in-1 Air Quality Sensor
  • WH57 Outdoor Wireless Lightning Detection Sens
Offline Gyvate
« Reply #88 on: October 07, 2021, 10:57:08 AM »
it's not always heating - there is a thermostat, but what its upper and lower thresholds are I don't know.
If you take a look at the graphs earlier posted by me in this thread, you can see that the temperature  ups and downs only occur at temperatures below 0° C.
Offline DelChard
« Reply #89 on: December 17, 2021, 08:25:00 AM »
Apologies if this has been pointed out elsewhere.
Extract from WS80 manual.
Might be useful to anyone researching potential hardware purchase.
Offline Gyvate
« Reply #90 on: August 19, 2022, 02:58:30 AM »
I know it's an old thread - but in order to keep things together in +/- one place I want to post the socket description of the Ecowitt 12V/1A DC power supply outlet I happened to received from Ecowitt:
I hope it will be useful for somebody wanting to use their own power supply.
I needed this info as I want to use the cable end with the power supply and with a solar panel (which needs a USB plug) interchangeably. Otherwise I would just have cut off the end and soldered a USB plug to it.
« Last Edit: August 19, 2022, 03:12:57 AM by Gyvate »
Offline src
« Reply #91 on: June 02, 2023, 06:16:31 PM »
This looks as though it may be compatible
https://www.amazon.co.uk/DULEE-Extension-Waterproof-Spotlights-Garden/dp/B08XM3MQRR
UPDATE: DON'T BUY THIS. I ORDERED THIS AND THE CABLE THEY SENT HAS DIFFERENT CONNECTORS TO THOSE IN THE PHOTO IN THE AMAZON LISTING!!!
« Last Edit: June 08, 2023, 08:42:54 AM by src »
Offline Rover1822
« Reply #92 on: June 08, 2023, 12:27:49 PM »
Just replying to push this up so others see your response about it not working
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
