Author Topic: PHP 8.1 and ajax-dashboard6.php - new deprecated notices  (Read 5584 times)
Offline andro700
  • Chuck
    • Gobles Weather Page
Re: PHP 8.1 and ajax-dashboard6.php - new deprecated notices
« Reply #25 on: April 06, 2022, 02:29:37 PM »
Hey Ken,
Have another issue, this time it is the radar status. You can see the radar status in the yellow box.
https://www.goblesweather.com/wxgr3hanis-dbZ.php
Chuck
« Reply #26 on: April 06, 2022, 03:08:17 PM »
You're peeling them out of the woodwork, Chuck. :)
Try this and see if that fixes the issue.
Offline andro700
  • Chuck
« Reply #27 on: April 06, 2022, 03:16:28 PM »
And again it fixed it. But will keep an eye on it. Will let you know if I find anything else.  ;)
Chuck
« Reply #28 on: April 06, 2022, 03:32:29 PM »
I pushed the radar-status.php V1.19 to the distribution.. thanks again, Chuck.
Offline andro700
  • Chuck
« Reply #29 on: April 07, 2022, 03:37:06 PM »
Found another issue with the Version 4 advforecast. Here is the error,
Fatal error: Uncaught ValueError: strpos(): Argument #3 ($offset) must be contained in argument #1 ($haystack) in /home/goblesweather/www/www/advforecast2-V4.php:687 Stack trace: #0 /home/goblesweather/www/www/advforecast2-V4.php(687): strpos('', '<td colspan="2"...', 1) #1 /home/goblesweather/www/www/ajax-dashboard6.php(206): include_once('/home/gobleswea...') #2 /home/goblesweather/www/www/index.php(89): include_once('/home/gobleswea...') #3 {main} thrown in /home/goblesweather/www/www/advforecast2-V4.php on line 687
« Reply #30 on: April 07, 2022, 03:46:08 PM »
That's likely caused by a failure to get the forecast from weather.gov site.  Check your cache/forecast-WAC033-0.txt file for text.
Run the advforecast2-V4.php?force=1 on your site to refresh the cache.
Offline andro700
  • Chuck
« Reply #31 on: April 08, 2022, 12:49:32 PM »
Hate to do this again but check out my metar page https://www.goblesweather.com/wxmetar.php. Several warnings and deprecated issues.
Chuck
Offline 92merc
  • BismarckWeather.net
« Reply #32 on: April 08, 2022, 02:13:40 PM »
Interesting.  I'm running PHP 8.1.3.  Upgraded earlier in the week from 8.0.  I'm not having any issues with my METAR page.  GoDaddy hosting.
https://www.bismarckweather.net/wxmetar.php
Offline andro700
  • Chuck
« Reply #33 on: April 08, 2022, 02:28:11 PM »
I am using ICDSoft hosting. I think I just fixed it. I had a metar that was not active. I will watch it  and see how it goes.
Chuck
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #34 on: April 08, 2022, 06:52:36 PM »
Chuck
I think you still have issues on your site:  https://www.goblesweather.com/check-fetch-times.php
Regards Simon
Offline andro700
  • Chuck
« Reply #35 on: April 11, 2022, 01:53:09 PM »
Yes I do. I have several pages that do not like PHP 8.1. Here is a list of pages that I have issue with. I am not sure if it is my PHP settings on my webhost or is it the script needs a modification to fix these issue. Plus I need to contact the author of the scripts to see what they say. I know some of them are older scripts.  I would appreciate any help possible.
https://www.goblesweather.com/wxaqirssV2.php
https://www.goblesweather.com/wxhilowavg.php
https://www.goblesweather.com/wxraintemptrends.php
https://www.goblesweather.com/wxextremes.php
https://www.goblesweather.com/wxastronomy.php
This script has jpgraph used by sunposa.php. There are issues with jpgraph with PHP8.1. I have updated to Version 10.4 and it did help out some.
https://www.goblesweather.com/wx_lvn_wxsimD.php
https://www.goblesweather.com/wxgraphicalfc.php
The fault occurs when you choose 3-4 days and then the fault stays on the page. When you initially open it up there is no fault.
Chuck
« Reply #36 on: April 11, 2022, 04:30:56 PM »
Ah... those scripts are generally not mine, except for the worldextremes.php script which you should update from https://saratoga-weather.org/scripts-NWSmisc.php#NWSEXTR
The others will either have to be fixed by their authors or by you using the error_log as a guide on what to fix.
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #37 on: April 11, 2022, 06:09:24 PM »
you must have a different wxastronomy.php than me perhaps?
mine works under 8.1.4
https://www.conligwx.org/wxastronomy.php
« Last Edit: April 11, 2022, 06:22:27 PM by ConligWX »
Regards Simon
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #38 on: April 11, 2022, 06:30:50 PM »
The 'wxgraphicalforecast.php' script is mine, but I haven't upgraded my site's PHP to 8.1 so I don't have any way to reliably debug the script.
I'll work on it as time permits, but the $SITE[] and $SESSION[] arrays are problematic.  My efforts thus far have been in vain.
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline gwwilk
« Reply #39 on: April 11, 2022, 07:07:15 PM »
Well, I apparently used a shortcut with this script and never noticed the error that was present in my version of PHP, 7.4.
I think I've sorted the problems and that the script behaves as intended.
A new wxgraphicalfc.zip is available on my scripts page.
gwwilk@gmail.com
Offline andro700
  • Chuck
« Reply #40 on: April 12, 2022, 12:24:41 PM »
Is there a way to force a update to the worldextremes script? My page is not working correctly it is blank.
Chuck
« Reply #41 on: April 12, 2022, 01:16:38 PM »
Yes, include ?force=1 on the URL of the page displaying the contents of worldextremes.php.
Looking at view-source:https://www.goblesweather.com/worldextremes.php shows the script is working correctly.  Keep in mind, the script doesn't directly display anything.. it just loads the appropriate variables for you to print/echo the contents on your page.
For example, my own page uses
<div id="main-copy">
<?php include_once("worldextremes.php");
print
"<div class=\"story\">\n";
print
"<h1>Weather Extremes for $reportDate</h1>\n";
print
"<p>&nbsp;</p>\n";
gen_display("World"." (omitting $omittedCountry)",$worldhigh,$worldlow,$worldprecip);
gen_display("Canada",$countryhigh,$countrylow,$countryprecip);
gen_display("USA (lower 48)",$usahigh,$usalow,$usaprecip);
list(
$glhigh,$gllow,$glprecip) = scan_for($worldStations,"United States","AK",$tUOM,$rUOM);
gen_display("Alaska"."",$glhigh,$gllow,$glprecip);
gen_display("California",$statehigh,$statelow,$stateprecip);
list(
$glhigh,$gllow,$glprecip) = scan_for($worldStations,"United States","HI",$tUOM,$rUOM);
gen_display("Hawaii"."",$glhigh,$gllow,$glprecip);
print
"<p><small><strong>Data from <a href=\"https://www.cpc.ncep.noaa.gov/products/cadb/\">NOAA Climate Prediction Center</a>.  ";
print
"worldextremes.php script by <a href=\"/scripts-NWSmisc.php#NWSEXTR\">Saratoga-weather.org</a></strong></small><br/>"."\n";
print
"Raw-data CSV file <a href=\"".gen_url($utcUse)."\">Download</a></p>\n";
print
"</div>\n";
function
gen_display($legend,$hightemp,$lowtemp,$precip) {
print "<h2>$legend</h2>\n";
print "<table style=\"border: none;\">\n";
print "<tr><td><span style=\"color: red\"><strong>High Temperature:</strong></span></td><td>$hightemp</td></tr>\n";
print "<tr><td><span style=\"color: blue\"><strong><br/>Low Temperature:</strong></span></td><td><br/>$lowtemp</td></tr>\n";
print "<tr><td><span style=\"color: green\"><strong><br/>Precipitation:</strong></span></td><td><br/>$precip</td></tr>\n";
print "</table>\n";
print "<p>&nbsp;</p>\n";
</div><!-- end main -->
Offline andro700
  • Chuck
« Reply #42 on: April 12, 2022, 01:46:44 PM »
Thanks Ken did not realize I had to put all that with the include. Page is working now. This will be a work in progress. My astronomy page was done by Bashewa and TNET so that script is going to be a challenge. I changed back to the more basic page. Working on JPgraph with Broadstairs. I emailed Murry on the raintemptrends, wxnoaarecords scripts. Waiting on a answer from him. My local AQI was done by Relay. My wxsim is done by Wim. So will have to get a hold of him.
Chuck
Offline yamiacaveman
    • Penn Lake Weather
« Reply #43 on: October 02, 2022, 12:50:24 PM »
Hey ConligWX Who wroe your wxastromy.php script? Mineis by Kevin Reedand not working in 8.1
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #44 on: December 30, 2022, 06:34:13 PM »
belated I know, my appologies.
// Version 1.01 - 22-Jan-2012 - fixes for mixed date format translations.
#   Project:    Sample Included Website Design
#   Module:     sample.php
#   Purpose:    Sample Page
#   Authors:    Kevin W. Reed <kreed@tnet.com>
#               TNET Services, Inc.
Regards Simon
« Reply #45 on: December 30, 2022, 06:40:21 PM »
I’ve updated the ajax-dashboard6.php, ajaxWDwx3.js and cloud-base.php in release 6.95f in the legacy-scripts on my site.
Offline DW7240
    • The Vicarage Weather Feed
« Reply #46 on: December 31, 2022, 04:05:52 PM »
I have noticed since updating to php 8.1 that 1 or 2 scripts don't work, but on the whole and with much gratitude to those involved with upkeeping the scripts, the update went smoothly.  One script that is completely down is the "include-wxastronomy.php"  I have read that users have reverted back to the original script and had little to no issues, my version attached worked with php 7, but fails to load with current php version.  Any help or advice would be appreciated, otherwise as I said above, transition to newer php no issues.
Thanks. Nick. dw7240.com
Offline mexbound
« Reply #47 on: December 31, 2022, 04:32:43 PM »
I noticed that in the latest ajax-dashboard6.php 695f there are still some ${ variables.
Offline Vasco
    • PWS
« Reply #48 on: December 31, 2022, 04:42:31 PM »
Is this any help?
« Reply #49 on: December 31, 2022, 06:42:03 PM »
That wasn't the problem.. it was some older code in getMoonInfo() and a few Notice errata.  Now fixed and works with PHP 8.1
