I have recently bought wifilogger 2.0 with firmware version 2.26 for my davis vantage vue console. It was working fine for 1 month.
And now it is not updating data to weatherlink/wunderground once in a while and I have to press white button to make it online again. Also Wunderground rapid update is failing and when i checked the debug log, it has "Connection to rtupdate.wunderground.com failed" logs appearing often. Below are the sample logs.
RapidFire
Renew RTD
Renew HiLows
RapidFire
Renew RTD
RapidFire
Client response time: 550
success
Is it an issue with Wunderground or with the wifilogger device? Also any idea why it should stop working once in a while and reset required? FYI.. I'm checking the debug log through web access "http://192.xx.xx.xx/debug".
I have seen the same. It is not WiFiLogger problem, but WeatherUnderground problem.
I remember that when WiFiLogger1 was released. There was a problem with CWOP.
cwop.aprs.net is an address to 7 different servers. 3 serves were rejecting data, so data was recorded in same patter as RapidFire now.
5 goes ok, then 1 not, then 2 ok, then 7 not.
I would like to wait some while, then start looking any issue. Server address is the same in any other software, like WeatherLink.com etc.
For rebooting:
Please turn on STAY ALIVE function in SETUP -> SYSTEM.
Stay Alive: Router & Google.
It will check Internet connection every 1 min to router and every 60 min. to Google server. Reconnect or/and reboot itself if needed it.
I will turn this option as default with new firmware.
