VWS is running on a Dell (about 3 yr old) with XP-Pro and 2G memory. It runs fine and sends data to
http://boltassociates.com/weather/wx.htm. However, about once a week the program just quits. The screen shows the desktop and VWS is not running. If I click on the VWS icon or reboot, VWS starts up again with no apparent problem.
Generally, there is no indication of what caused the problem. I'm running the last update. This morning there was a message indicating a problem with cvirte.dll. VWS was still on the screen and appeared to be in the process of ftping to the web, but the time indicated it had been trying for a couple of hours.
Does anyone experience the same problem? And, if so, how have you fixed the issue?
doug bolt
