Author Topic: PWSweather.com offline here ...  (Read 14023 times)
Offline sam2004gp
  • Mount Crawford, Virginia
  • Weeeeeeeee!!!!
    • Mount Crawford Weather, VA
Re: PWSweather.com offline here ...
« Reply #25 on: December 31, 2009, 05:06:50 PM »
Ok thanks, I was just about to submit a support/login assistance request.  I will just set back and give you some more time to track down all of your bits and bytes.
Offline weatherforyou
  • Moderator
  • My weather is on WeatherForYou.com. Is yours?
    • http://www.weatherforyou.com
« Reply #26 on: December 31, 2009, 05:11:44 PM »
OK... I found part of the issue.  If you have upper and lower case in your login it doesn't work if entered correctly.  But if you put it in as all lower case it seems to work.  Absolutely looks like a php bug.  So if you absolutely, positively need to login try lower case.  If you can wait I'll update when it's been corrected.
Thanks to those of you being patient about this and for all the helpful information!  :grin:
Joe Torsitano
Offline sam2004gp
  • Weeeeeeeee!!!!
« Reply #27 on: December 31, 2009, 06:23:19 PM »
Ok great that was the fix for me.  I had some characters in my log-in name in capitals.
    • Watts Bar Weather
« Reply #28 on: December 31, 2009, 06:28:23 PM »
I thought characters in capitals were called politicians!   :roll:
  • Moderator
« Reply #29 on: December 31, 2009, 06:28:41 PM »
Bug has been found and squashed.  You should be able to login normally.  If for some reason you can't please file a support request at http://www.pwsweather.com/support.php
Thanks!
Joe Torsitano
  • Moderator
« Reply #30 on: December 31, 2009, 06:33:30 PM »
poly ticks = many blood sucking creatures.   :-P
Joe Torsitano
Offline racenet
    • NH Weather Data
« Reply #31 on: December 31, 2009, 06:38:16 PM »
Ok I'll just turn the switch to off. My data not that important
Damn man, what crawled up your butt?  :roll:
Offline Mark / Ohio
  • Live from Mars!
    • Fairfield County Weather
« Reply #32 on: December 31, 2009, 09:58:19 PM »
All's well here Joe.  Logged in and back out no problem.   :grin:  (Once I found where I wrote down my password.    #-o )
