Author Topic: PWSweather.com off-line for maintenance  (Read 4371 times)
Offline weatherforyou
  • Moderator
  • My weather is on WeatherForYou.com. Is yours?
    • http://www.weatherforyou.com
« on: July 31, 2009, 02:20:33 PM »
Due to the need for emergency maintenance (and an upgrade while we're at it) PWSweather.com will be down for a period of time later today.  We're still coordinating the exact time with the data center.  But just be aware we will be back.  Data has been backed up to a separate system in case of any catastrophic problems with the upgrade.
The affected server has been operating non-stop for 452 days so it deserves a few hours off.  ;)
Thank you for your patience.
Joe Torsitano
Offline sam2004gp
  • Mount Crawford, Virginia
  • Weeeeeeeee!!!!
    • Mount Crawford Weather, VA
Re: PWSweather.com off-line for maintenance
« Reply #1 on: July 31, 2009, 02:21:21 PM »
Thanks for the heads up.  Hope it goes smooth.
Offline Bandit
    • Haire Airport Weather
« Reply #2 on: August 01, 2009, 02:59:08 PM »
Just checking to see if the site is still undergoing maintenance.......I was able to log-in but getting various error messages when trying to click around........I also notice that my update to  weatherforyou.com  is "currently" 3+ hours old.......it "is" updating correctly on my end.  Just checking.........thanks!
Richard
WeatherHawk "521"
  • Moderator
« Reply #3 on: August 01, 2009, 03:13:15 PM »
It is still being worked on.  The update in the drive array did not go as smoothly as expected.  Engineers at the data center and an outside administrator are working on it at this time.
Joe Torsitano
Offline Bandit
« Reply #4 on: August 01, 2009, 03:15:57 PM »
OK, thanks!
Richard
WeatherHawk "521"
  • Moderator
« Reply #5 on: August 01, 2009, 05:22:23 PM »
PWSweather.com is back up and functioning with a few hardware improvements.  The table for one month's data (May 2009) was corrupted beyond repair and needed to be deleted, but it will be restored from backup later.
Joe Torsitano
Offline Bandit
« Reply #6 on: August 01, 2009, 06:08:53 PM »
Everything looks good on my end now......... =D>
Richard
WeatherHawk "521"
Offline killwilly
« Reply #7 on: August 02, 2009, 02:34:02 AM »
Joe
You may recall the problems I was having uploading to your site. Following the short shut down on Friday, my data started to upload again. However, it has stopped again since the Saturday off-line period, most strange. I closed and restarted VWS, but still no luck.
Alan.
Alan
Offline TorH
    • Været på Fauske
« Reply #8 on: August 02, 2009, 05:58:17 AM »
Just for the record, all seems to be working great from here.
Davis Vantage PRO2 wireless
VWS V14.00 p103, WD ver.10.37N, WL 5.8.2, VVP.
WeatherFlash
DW1549
WeatherUnderground: INORDLAN14
Location: Fauske, Northern Norway. N 67°15'41", E 15°24'41"
http://bjornli.net
