Author Topic: GW2000 Ambient Weather Upload. **solved**  (Read 1101 times)
Offline Adog33
« on: December 23, 2022, 08:33:58 PM »
Is the GW2000 uploading to Ambient weather now supported with Weather bridge / Meteobridge?
Previously there was some limitations with the rain sensor.
Which station would I pick in the drop down? I do not see GW2000 only driver for GW1000
« Last Edit: March 21, 2023, 11:08:00 AM by docbee »
Offline docbee
  • Moderator
    • smartbedded
Re: GW2000 Ambient Weather Upload
« Reply #1 on: December 24, 2022, 01:16:33 AM »
Please use the GW1000 driver. I think the GW2000 is the base station of the Wittboy?
However, if you have problems in receiving data, I should be able to adapt the driver if you grant me remote access.
Offline Adog33
« Reply #2 on: December 27, 2022, 07:15:09 PM »
Sounds good. The hardware is on order for the station.
« Last Edit: December 27, 2022, 11:20:53 PM by Adog33 »
Offline Adog33
« Reply #3 on: December 29, 2022, 05:37:29 PM »
Can anyone confirm If I should order the "Weather Bridge"  or build 3rd party DIY Meteobridge?
I'd like to use Weather Bridge as it already has the license, but Ambient support informed me their Weather Bridge does not support the GW1000 or GW2000 gateways.
Offline docbee
  • Moderator
    • smartbedded
« Reply #4 on: December 30, 2022, 03:13:36 AM »
Weatherbridge does support GW1000/GW2000, they use the original Meteobridge SW. If you are into local storage you might also look at Meteobridge PRO2 or builds on RPI. A needed License for Ambient Cloud will then of course add to your bill.
Offline Adog33
« Reply #5 on: January 18, 2023, 12:10:35 AM »
Meteobridge captures GW2000(Wittboy) and uploads to Ambient without issues, just had to manually map
a few sensors, and adjust pressure offset. Thank you!
Can you provide guidance on the template settings for FTP upload? Trying to upload to pwsDashboard.
Offline Gyvate
« Reply #6 on: February 05, 2023, 04:01:30 PM »
why do you want to use FTP upload ?
You can use the Custom Server functionality of the GW2000 along with pwsWD Dashboard (Ecowitt LCL) - unless you use this already for different purpose.
That's described in the PWS Dashboard documentation.
Offline wvdkuil
  • Wim van der kuil
« Reply #7 on: February 05, 2023, 04:25:54 PM »
Custom upload from your GWxxx is described here for PWS_Dashboard.
Dozens of users can answer your questions or help with problems at the pwsdashboard part of weather-watch-forum
