Author Topic: Mesonet no data  (Read 579 times)
Offline zeppline
    • Las Vegas Weather Guy
Mesonet no data
« on: September 02, 2022, 05:29:59 PM »
I upgraded from 4.04 to 4.09 the map is there but no data. What else to I have to change? Do I need a key?
Re: Mesonet no data
« Reply #1 on: September 02, 2022, 05:52:13 PM »
Using http://www.lasvegaswx.com/mesonet-map-check-versions.php shows you need to update multiple files from the mesonet-map.zip distribution.
The data on the map is not showing since mesonet-map-json.php is getting a 500-Server error, likely due to the downlevel version of mesonet-map-common.php
Update all the files and it should work fine.
« Last Edit: September 02, 2022, 05:54:04 PM by saratogaWX »
Offline zeppline
Re: Mesonet no data
« Reply #2 on: September 02, 2022, 06:03:44 PM »
Thanks Ken I did not look at the bottom of the page, I was looking for the zip
Re: Mesonet no data
« Reply #3 on: September 02, 2022, 08:20:01 PM »
Don't forget to update all the mesonet-map-lang-*.txt files too.. they're really PHP used in the language translations and are a required update when the site is updated to PHP 8.
« Last Edit: September 02, 2022, 08:21:33 PM by saratogaWX »
