The fan is actually fairly easy to replace, takes a few minutes:
1. Squeeze the front and back ends of the bottom plastic cover on the temperature vent stack to remove.
2. Remove the three long screws form the bottom of the temperature vent stack, use a standard philips screwdriver, not a mini- you will need the torque!
3. The 4 layers of the vent stack will now be loose, take the first three off exposing the fan layer.
4. Remove the battery compartment cover, then remove the four mini screws holding the battery compartment/electronics core in place.
5. Turn the core around and you will note all fo the wires from the separate sensing components are routed and plugged into the backside of the battery compartment. Find the wire labeled "FAN" and carefully unplug it.
6. Note the wire routing while you remove the wire from the housing, route the new fan unit the same way.
*7. Take a few moments to clean out the rain gauge bucket and internals for best performance
(follow the instructions backwards to reassemble)
