Author Topic: Can weewix read data from Ecowitt's Wittboy?  (Read 1334 times)
Offline BaseLine
« on: August 08, 2022, 01:37:19 PM »
Can weewix read data from Ecowitt's Wittboy? If yes, how?
Thanks.
Sun cooked nothing burger of climate change hysteria with a side order of peak-oil nonsense fries.
Offline Gyvate
Re: Can weewix read data from Ecowitt's Wittboy?
« Reply #1 on: August 08, 2022, 03:56:16 PM »
yes, with the new Ecowitt Gateway driver (old name: GW1000 driver) 0.5.0b5
https://github.com/gjr80/weewx-gw1000
more details - see https://github.com/gjr80/weewx-gw1000/wiki
WS2350 1.6.4, GW1000(3) 1.7.5, WH2650 WiFi (2) 1.7.5 (test/backup), GW1100 2.2.0, GW2000(3) 2.2.0, HP2551 1.6.4/1.8.6;
MeteobridgePro(2)[test,prod] 5.5 Oct 27 2022, 14854 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/CumulusMX 3214/MB RPi4(2886)
Offline BaseLine
« Reply #2 on: August 08, 2022, 04:10:36 PM »
Thank you.
Works like a charm. BTW, you also need a light web server to access it from your LAN. I used nginx-light.
I am running it on my NAS, that's on 24/7 anyway.
Offline Gyvate
« Reply #3 on: August 08, 2022, 04:27:10 PM »
if your server doesn't run already a webserver (that's a program/service to handle http/https requests), you will need to install one - that's pretty obvious  ;)
How would otherwise the html pages (index.html) be displayed in your browser ...
It has nothing to do with LAN or WAN - if an internet host (computer/server) doesn't run a webserver software, no http/https requests can be fulfilled.  8-)
Offline BaseLine
« Reply #4 on: August 08, 2022, 04:55:05 PM »
LOL. You do not need a web server if you can access the html page directly with your browser - that's pretty obvious ;)
Offline Gyvate
« Reply #5 on: August 10, 2022, 04:43:34 PM »
maybe "access it" was not the right choice of word here. You can access it from another server if no firewall rules and other permissions forbid it. You don't need a web server for this.
You can copy it, rename it, load it in an editor, many things you can do which mean (and need) to access it -
but you may not be able to view the translation of its content into a webpage, display this in a browser from another but the local host without a web server running on the local host.
