Author Topic: HTML code to make browser update automatically at inerval  (Read 2776 times)
Offline DaleReid
    • Weather at Eau Claire, WI
« on: May 09, 2022, 08:28:31 PM »
Is there a line of HTML code that will cause a browser, displaying a web page image, to update or refresh at intervals selected by the programmer?
ECWx.info
ECWx.info/t/index.php
Offline sky_watcher
Re: HTML code to make browser update automatically at inerval
« Reply #1 on: May 09, 2022, 09:06:48 PM »
Try this page for what you want:
https://www.geeksforgeeks.org/how-to-automatic-refresh-a-web-page-in-fixed-time/
“The more a man knows, the more willing he is to learn. The less a man knows, the more positive he is that he knows everything...” ― Robert G. Ingersoll
« Reply #2 on: May 09, 2022, 10:07:37 PM »
<meta http-equiv="refresh" content="500">
in the head.   time is in seconds
Offline DaleReid
« Reply #3 on: May 09, 2022, 10:09:11 PM »
Thank you. I'll look at the code to see if I can understand it, being the newcomer that I am.  Thank you again.  Dale
ECWx.info
Offline DaleReid
« Reply #4 on: May 09, 2022, 10:10:24 PM »
Chief, that is even simpler.  I know that they update code all the time and maybe this has been there for awhile, but this makes sense and I'm glad they have it as a function of html. Dale
ECWx.info
Offline Cutty Sark Sailor
« Reply #5 on: May 11, 2022, 08:22:25 AM »
Dale, I use this to ONLY reload a single image, instead of the whole page.... there's other ways, but this seems to work better for me:
<body onload="setTimeout('Cam1Still()',10000)">
<img id="stillSC" class="wxcam" src="../still/camSC.jpg?" alt="Accessing Server" />
<script>
function Cam1Still() {
   if (!document.images) return;
   document.getElementById('stillSC').src = '../still/camSC.jpg?' + Math.random();
   setTimeout('Cam1Still()',10000);
</script>
The Body tag replaces current 'naked' body tag, or add the 'onload' thingy into the tag.
This reloads every 10 seconds.'Cam1Still' is function name... name it what you will, both places...
Give the 'image' an 'id', and put it both places. ('stillSC' in this example)
Then of course, the image source... ('src') both places
'?' is important.
https://frankfortweather.us/camsUP/stillNW.html e.g.
Mike
« Last Edit: May 11, 2022, 08:30:55 AM by Cutty Sark Sailor »
Offline DaleReid
« Reply #6 on: May 11, 2022, 08:30:48 AM »
Again, more ways to do things, and like our language, the computer code has many ways to 'say' something.
Thanks to all who have given me examples to study and to help understand how things work. Dale
ECWx.info
« Reply #7 on: May 11, 2022, 06:09:47 PM »
<script>
</script>
'?' is important.
Mike
Will that work to update the WU radar package and not the whole page?
Offline BCJKiwi
    • Silver Acorn Weather - N.Z.
« Reply #8 on: May 12, 2022, 09:42:24 PM »
This code synchronises the refresh to time of next update and as configured does the refresh 35 seconds after the update.
For the Saratoga tempalate I have placed it in top.php
// synchronise page refresh to tags upload time - assumes correct time zone set in php scripts to match WXsoftware timezone
// $timeofnextupdate is standard site variable in Saratoga template for both CU & WD but calculated for CU
if (isset($timeofnextupdate) && $timeofnextupdate != '---' ) {
   $nextupd = (substr($timeofnextupdate,0,2)*60*60) + (substr($timeofnextupdate,3,5)*60); // next update hh:mm as seconds
   $present = (date('H')*60*60) + (date('i')*60) + date('s');                             // now hh:mm:ss as seconds
   if ($nextupd > $present) {$metrefresh = $nextupd - $present + 35;} else {$metrefresh = 620/2;} // handle midnight
// echo "timeofnextupdate (hh:mm): " . $timeofnextupdate . " = nextupd (secs): " . $nextupd .", present (secs): ".$present . ", refresh (secs): ". $metrefresh . "  - HH:" . date('H') . " MM:" . date('i') ." SS:" . date('s') . " tagtime: " . $time;
 } else { $metrefresh = 620; }
// echo "default refresh: ". $metrefresh; // default
   <meta http-equiv="refresh" content="<?php echo $metrefresh?>" />
Offline weatherdoc
    • Willowsford Farm Weather
« Reply #9 on: May 14, 2022, 08:29:03 AM »
Hey chief-david, thanks for the code snippet. I had been updating my entire wxcam page each minute but implemented your code so that just the still image updates every 10 seconds: https://novawx.dscloud.me/wxcam.php
« Reply #10 on: May 14, 2022, 08:41:09 AM »
Now my question....how can I put this in the WU radar package and not have to update the whole page?
« Reply #11 on: May 14, 2022, 08:42:29 AM »
The images can be stuck in a cache, even if the entire page is refreshed.
I use this random number generator trick to force an image refresh. This is a particular problem with some of my generated charts on my site.
See this post: https://www.wxforum.net/index.php?topic=43665.msg444653#msg444653 for a how-to. I didn't come up with this solution, I found it somewhere on the web a few years back.
« Reply #12 on: May 29, 2022, 08:40:38 AM »
After all of this time--I put my meta  info into the WU radar package.
It reloads the radar, and not the whole page!!!!!! Wish I knew this 10 years ago-especially when I was able to go to live data.
<!DOCTYPE html>
<html lang="en">
<head>
<title>WUradar</title>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1">
<meta name="Keywords" content="weather, Weather, radar" />
<meta http-equiv="refresh" content="180">
<link rel="stylesheet" href="https://www.w3schools.com/w3css/4/w3.css">
<style>
Offline DaleReid
« Reply #13 on: May 29, 2022, 01:34:59 PM »
David, interesting observation.  Thanks for sharing your discovery.
Dale
ECWx.info
« Reply #14 on: May 29, 2022, 03:52:25 PM »
Ummm... the
<meta http-equiv="refresh" content="180"> in the <head> part of the page causes the browser to reload the page..all the page.  Only JavaScript can be used to reload parts of the page.. that's how the AJAX scripts (ajaxWDwx.js, etc) work to refresh PART of the page (specifically marked areas) from a more frequently updated conditions file.
