Author Topic: WSV3 question  (Read 1438 times)
Offline ashleygamergirl
WSV3 question
« on: May 04, 2022, 03:32:14 AM »
Hello,
I have been using WSV3 to track storms in Oklahoma. I had my loop in the upper right corner set to 6 hours. I waited about an hour or two and clicked the play button to watch the loop of accumulated data. The timestamp and frame switched to the time/frame that I started tracking, however, a second or less later, it immediately skipped forward and I could only watch like 15-25 minutes in my loop instead of the full 6 hours. I chocked it up as a bug or something and set it up to run while I was at work today. I came up, and the exact same thing happened again. I don't know if its dumping my data or what. Does anybody have any advice with this?
Also, is it possible to save all of the data I record in a session so I can view it later? I scoured the instruction manual and couldn't figure it out.
Edit: I should also mention I was recording Nexrad level 2 data.
« Last Edit: May 04, 2022, 03:34:02 AM by ashleygamergirl »
