Author Topic: Override GW1000 Indoor Sensor  (Read 279 times)
Offline Zimerhonzl
    • TexWx
« on: January 19, 2022, 06:25:08 PM »
I have had to shift my GW1000 to an out building to pick up all of my sensors.  As such, I have lost the proper indoor reading.  I have already seen that a WH32B will not work with a GW1000 (https://www.wxforum.net/index.php?topic=40730.0), so I was curious if there is any other way/sensor to override the indoor temperature reading.
TIA,
Jonathan Z
Online Gyvate
Re: Override GW1000 Indoor Sensor
« Reply #1 on: January 19, 2022, 07:20:29 PM »
You could use a combination of a WH31 (multi-channel extra temperature/humidity sensor) and the FOSHKplugin and remap the WH31 reading to you indoor T/H. However, for the FOSHKplugin you'll need a computer running 24/7 (could be a Raspberry Pi or also a Windows  10 or 11 PC [where you could run FOSHKplugin in the WSL environment: Windows subsystem for Linux]).
You could display these values via the Android Personal Weather Station app - having the GW1000 post its readings to FOSHKplugin and FOSHKplugin doing the remapping and forward it to the app/tablet.
When you use application software like Meteobridge or weewx, you can also do a remapping. The WH31 will also be needed here.
« Last Edit: January 19, 2022, 07:25:34 PM by Gyvate »
Froggit WH4000SE (=EW 2320E) 1.6.4/GW1100 2.1.4/Froggit DP1500 1.6.8 (+EW GW1000 (4) 1.6.8/7.2 test/backup)/HP1000SE Pro (HP2551) 1.6.4/1.7.8, WH2650 WiFi (2) 1.7.2,GW2000 2.1.4;
Ecowitt WS90-ß,WS80,WH40,WH65,WH31(5),WH31-EP(1),WN30/DP30 (1),WH32(1),WH32-EP(1),WH32B [T/H/P] (1), WH57 [Lightning] (1), WH41 [PM2.5] (2), WH51 [SoilMoisture] (5), WH45, WH55 (2)
MeteobridgePro(2)[test,prod 5.4 May 07 2022, 14745 - Blake-Larsen Sun Recorder - RPi4/weewx 4.5.1/CumulusMX 3183/MB RPi4(2671)
Barani Meteoshield Pro, MetSpec Rad02
Ecowitt 5763,34418;WU ISAARB3(WH4000SE), ISAARB22(HP2553), http://meshka.eu
Offline davidefa
« Reply #2 on: January 19, 2022, 08:05:25 PM »
Others have found that extending the antenna out of the case improves the rf reception ( don't remember the exact post, this shows the antenna, the red wire on the left https://www.wxforum.net/index.php?topic=36912.msg379624#msg379624 ).
You may give it a try.
Offline Zimerhonzl
    • TexWx
« Reply #3 on: January 21, 2022, 04:22:31 PM »
Thanks to you both.  I'll likely try extending the antenna out of the case initially.  If that doesn't work, I will do some remapping in Weewx.
