Author Topic: Pressure systems and fronts  (Read 341 times)
Offline hf17
« on: January 10, 2022, 06:43:16 PM »
This might be a really stupid question, but why do fronts only form around low pressure systems?
Offline Cutty Sark Sailor
Re: Pressure systems and fronts
« Reply #1 on: January 10, 2022, 07:08:23 PM »
Do you mean:  "Why are cold fronts associated with low pressure systems,and warm fronts associated with high pressure systems?"  Then there's the occluded cold/warm/cool sandwich and the stationary rock'n'uh'hard-place  hand-wrestle of cold/warm, etc.
« Last Edit: January 10, 2022, 07:29:29 PM by Cutty Sark Sailor »
« Reply #2 on: January 10, 2022, 07:17:04 PM »
« Reply #3 on: January 10, 2022, 07:53:32 PM »
Ridges have no fronts.
https://www.weather.gov/media/epz/WXBasics/WXBasics-Fronts.pdf
:oops: .... perhaps it's a perspective / semantic convention?
 :D A front is the boundary between two air masses of
different temperatures.
A ridge is a line of relatively high pressure out of a defined high....doesn't the ridge and associated high drive the warm air into the cold mass?.
« Last Edit: January 10, 2022, 07:59:03 PM by Cutty Sark Sailor »
« Reply #4 on: January 10, 2022, 07:59:49 PM »
Only because there's a trough preceeding it. No trough, no front.
« Last Edit: January 10, 2022, 08:07:41 PM by CW2274 »
Offline TheBushPilot
  • Storm chaser and independent researcher
« Reply #5 on: January 10, 2022, 08:23:20 PM »
Firstly, there are no stupid questions, unless it is legitimately stupid. Which this one is not, only those that are unasked in my opinion are.
If I understand your question right, you're referring to cyclogenesis and the fronts associated with them? I don't know enough about meteorology to for sure say they only form on low pressure systems but that sounds right. From my understanding it's just the nature of the contiguous United States and the topography that influences the structure of the mesoscale systems that occur here. Like every Nat Geo documentary talking about tornado formation, you've got a jet coming from over the Rockies in the west, as that evolves it produces a cyclone. With that cyclone you simultaneously have a Bermuda high (high pressure situated around the Bermuda region in the ocean) pushing moisture up through the gulf and into the low system causing warm air advection. As that low propagates east north eastward or really where ever it wants to go you've got the cold air from the north and west butting up against that warm southerly flow. Thereby creating fronts. From what I understand that's how it works. :-s
If anyone is more knowledgeable please correct me if I got anything wrong or add to what I've said. :roll:
Hopefully that answers your question.
Cheers,
Quinton
"There is — always — more than one thing influencing anything we are trying to measure." ~ Sherman Fredrickson
"Well right now I don't feel very damn researchy" ~ Tim Samaras
"Do it right or don't do it at all."
05103 (4), HMP35C (4), CR10X (2), 61302L (1), TV-114 (1), TD-104-5D (1)
LOGGERNET, GR2Analyst
« Reply #6 on: January 10, 2022, 08:39:06 PM »
Fronts are the same the world over. The big difference is that in the northern hemisphere, cyclones rotate counter-clockwise, in the southern, clockwise.
