Author Topic: Extend the 6-pole cable for the temperature sensor  (Read 630 times)
Offline mihec
« on: January 09, 2022, 11:23:01 AM »
after months of comparison I conclude that temperature recorded in the original non-FARS Davis shield is higher for about 1-1.5 degC at solar noon but also higher in cloudy conditions. My reference is a 1-wire (actually 2 sensors) temperature sensor in a nearby Stevenson screen.
I wanted to move the temperature sensor from the Vantage Pro2 into the Stevenson screen but my homemade extension cable did not work.  I used an 8-pole (RJ-45) connector block and plugged the 6-pole connector on both sides ( sensor --> RJ-45 block --> ISS )
Is it even possible to extend the cable? I need a couple of meters, preferably up to 10m. I want to use my existing Stevenson screen and avoid buying a relatively expensive FARS.
Thanks.
Offline mcrossley
    • Wilmslow Astro
Re: Extend the 6-pole cable for the temperature sensor
« Reply #1 on: January 09, 2022, 12:49:43 PM »
IC2 cables are normally short distance, 2m or less. I believe you can go quite a bit longer but you need to pick the cable carefully to avoid capacitance issues. No twisted pairs and limited shielding are probably the way to go.
I know the SHT sensors Davis use are not IC2, but the electrical interface is the same I believe.
Offline Mattk
« Reply #2 on: January 09, 2022, 03:54:07 PM »
The RJ45 connector sounds like a cross-over, you could need a straight through version?
The other thing is your extension cable could be crossed over to begin with?
« Last Edit: January 09, 2022, 03:58:38 PM by Mattk »
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
« Reply #3 on: January 09, 2022, 07:57:10 PM »
Just use ya phone camera or a magnifying glass to look at both connectors, check to make sure all the colours line up both ends and line up with the original temp cable. When i extended the rain bucket and the UV and Solar sensors, I am sure I used the cable from Davis, i am also quite sure i have to add new connectors for at least the solar and UV, to be honest i cannot remember 100% as it was a while ago now but i am quite certain it was the davis extension cable i used and i am sure i had to be mindful as to what the wires were doing and that some were only 6 core, just cant remember now sorry. Deffo double check to make sure all your colours line up, both ends and from the original cable, i found it easier to write it down, i drew a small diagram of the original connector and lettered each colour to the connector and the same with the new cable. I just found it easier  is all as i get confused easily lol
Kind regards
Bashy
Offline mihec
« Reply #4 on: January 10, 2022, 02:30:54 AM »
Thanks, not a native English speaker so I cannot explain the "RJ-45 block" better. It is basically a block with RJ-45 on both sides and the wires are "through". I don't think they're crossed, but I'll verify with an Ohmmeter. I hesitate to cut the original connector and solder an extension cable since this is almost irreversible thing :-) I'm mostly afraid the length of the cable does matter here that's why I asked. I think the extra temperature sensors come with longer cable? I'll try to find more from Davis, if they reply.
Offline Mattk
« Reply #5 on: January 10, 2022, 04:33:31 AM »
Standard VP2 Temp/Humidity sensor/s typical come with a 2 feet cable. there is also a longer cabled version of the Temp/Humidity combo available with a 25 foot cable, 25 feet is the Maximum cable length and probably why Davis doesn't make any 6 core extension cables.
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #6 on: January 10, 2022, 06:16:41 AM »
If you do any customization work more than once it is worth it to get the Cutter/Stripper/Crimper tool, some connectors and a bit of flat wire.
Make needed cables from original material, just long enough, but not excessive.
Offline Phil23
    • Phil's Backyard
« Reply #7 on: January 10, 2022, 05:07:30 PM »
Yes, and 2 metres is really making a stretch with everything in your favour.
I do wonder how much luck you could have with some type of active extender or repeater.
The simplest of searches shows a few devices like this https://www.google.com/search?q=PCA9515A
Maybe a a few of them alone the line could extend to a reasonable distance.
(During my time on the Steel Works in the '80's we built similar things to extent RS232 at 300 Baud. They existed about every 50-100m).
Edit:- Scrap that, two or more cannot be placed in series as per the data sheet.
https://html.alldatasheet.com/html-pdf/107978/PHILIPS/PCA9515A/596/2/PCA9515A.html
« Last Edit: January 11, 2022, 04:00:05 AM by Phil23 »
Offline jerryg
  • weather is never boring
    • victoria texas weather
« Reply #8 on: January 10, 2022, 07:30:58 PM »
I have had no problem extending the sensor cable up to 50 feet with cat 5 cable and a cat splice.
« Reply #9 on: January 23, 2022, 06:33:20 AM »
This is what I did to make use of a stevenson screen.
« Last Edit: January 23, 2022, 06:37:54 AM by Monto Weather Qld Australia »
