Author Topic: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test  (Read 48101 times)
Online olicat
  • GWxx00, HPx5x1C, WN1900C, WN1980C & WS3800C
    • FOSHKplugin
Re: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter
« Reply #175 on: February 01, 2022, 06:23:45 AM »
Hi!
Very nice. This is the first real comparison I've seen here. Thanks for that!
Oliver
Offline Gyvate
« Reply #176 on: February 01, 2022, 06:30:48 AM »
some statistics down here:
the 1-Feb line may still change until the end of the day  8-)
« Last Edit: February 01, 2022, 06:35:27 AM by Gyvate »
Offline hiljo
    • Weerstation Hattem
« Reply #177 on: February 01, 2022, 06:35:55 AM »
Thanks for your compliment. I don't wanted to compare only the rain, but also the temp, hum, wind, solar, etc. The haptic rain sensors are quit difficult to understand though..
Now for example, we have a constant very light drizzle, and that's not measured (almost none). When we have moderate/heavy rain, it is overrated, and the values are too high.
Also the solar radiation is very different to the WS80.
I don't have a manual reference for rain or solar radiation, so the comparisons are quite 'relative'. None of them could be the real truth.
Ecowitt HP2550C v1.9.3
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Smart Sensors (WFC01 & AC1100) beta tester
3x WH31, WH32, WH40, WH41, WH57
WN34L, 2x WH51, WN35, WN34D
Dutch translator for Ecowitt.
https://www.weerstationhattem.nl/
Offline Gyvate
« Reply #178 on: February 01, 2022, 06:45:54 AM »
My WS90 is mainly set up for rain measurements. I. e. 2m above ground as per recommendation of DWD (1,5-2m).
My WS80 is much higher up.
Differences in wind measurements are therefore very likely to occur.
I also noticed differences in the solar radiation measurements (delta + 20 W/m2), but they again have different exposure at this time of the year due to my location. For such observations April-September would be a better time period.
So, comparisions for wind and solar will come about later.
Offline davidefa
« Reply #179 on: February 01, 2022, 06:46:34 AM »
@hiljolodewijk
Great comparison page... may I suggest:
- adding a zoom to the charts ( as it is done with highcharts: chart: { zoomType: 'x' } )
- adding a 'startdate' parameter to the page ( so that ??interval=24&startdate=2022-01-28 00:00:00 show only one day data )
P.S.
Only small differences from these preliminary data:
- with light rain ( to be expected, as it is difficult bo be detected )
- with higher rain rate ( maybe only a recalibration after full testing )
« Last Edit: February 01, 2022, 06:52:25 AM by davidefa »
Offline hiljo
« Reply #180 on: February 01, 2022, 06:54:58 AM »
@hiljolodewijk
Regarding the first, this was already possible (although I didn't tell you  ;))
https://www.weerstationmarsdijk.nl/ws90beta.php?historical_date=2022-01-29
Added Zoom X. By dragging the mouse on the graph you can zoom in to that part.
Also clicking the items in the legenda disables/enables the values. Sometimes handy to exclude the total rain calculations to only see the rain intensity.
« Last Edit: February 01, 2022, 06:58:11 AM by hiljolodewijk »
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Online olicat
    • FOSHKplugin
« Reply #181 on: February 01, 2022, 07:39:57 AM »
Hi hiljolodewijk,
are you able to integrate the min & max of these sensors and the delta?
Something like the temperature comparison attached.
Oliver
Offline hiljo
« Reply #182 on: February 01, 2022, 07:52:01 AM »
It is all stored in a MySQL database. So yes it is possible (calculate the diff), but currently not regarding the time. If i have some time left, I can see what I can do. But it also brings scripting and some graph adjustments sometimes.
Why do you want to see the mins/maxs/delta's?
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Offline giusCB
  • www.turismometeo.it
« Reply #183 on: February 01, 2022, 08:23:01 AM »
This is a good manual rain gauge
TFA 47.1008
www.turismometeo.it
Offline Gyvate
« Reply #184 on: February 01, 2022, 08:38:38 AM »
TFA 47.1008
[tup]
I'm using two:
47.1008 and 47.1001
1008 is my Man1 and 1001 is my Man2 in my table
Offline giusCB
« Reply #185 on: February 02, 2022, 05:14:49 AM »
this trend seems to be present on the other online stations as well, but these are only first impressions... they should be confirmed with other datas  [tup]
www.turismometeo.it
Offline Gyvate
« Reply #186 on: February 02, 2022, 12:57:31 PM »
EDIT: end-of-day update
« Last Edit: February 02, 2022, 04:09:12 PM by Gyvate »
Offline tweatherman
« Reply #187 on: February 02, 2022, 09:38:29 PM »
Just curious how the temperature and humidity are tracking in the new stations radiation shield compared to other ones? Haven’t had a chance to mount mine yet do to snow and windy conditions here.
tweatherman
Offline hiljo
« Reply #188 on: February 03, 2022, 01:39:48 AM »
See my page.
Only this is a comparison between the WS32 1 meter lower in the shadow and the WS90.
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Offline Gyvate
« Reply #189 on: February 03, 2022, 03:02:28 AM »
tweatherman
I think for that it's not the right season yet for stations mounted in Europe. Would need to be > April with long(er), hot sunny days ...
Right now it (the performance) is +/- 0.1 °C compared with my WH65, WS80, WH32-EP, but I wouldn't consider this as solid results ...
« Last Edit: February 03, 2022, 05:02:08 AM by Gyvate »
Offline davidefa
« Reply #190 on: February 03, 2022, 03:49:31 AM »
Sorry to bother you... but:
- with separate tooltips it is quite difficult to see values for both curves (  'tooltip: { shared: true }' should solve this, see demo )
- solar radiation graph 'does not understand' the interval parameter
P.S.
Quite strange wind bearing from yesterday 18:00:
- ws80 shows an average  north bearing
- ws90 shows an average south bearing
Offline Gyvate
« Reply #191 on: February 03, 2022, 09:03:42 AM »
EDIT: wrong picture inserted, now replaced
« Last Edit: February 03, 2022, 09:07:20 AM by Gyvate »
Offline BliXem
« Reply #192 on: February 03, 2022, 09:50:23 AM »
So, the GW2001 really worth it to buy? I've got the Tempest weatherstation, but not happy about it. Much unaccurate rain, and I also got a problem with jet fighters which are flying low here which triggers rain. Like today, two jet fighters did come by to see the weatherstation (ofc not) and there was 1.8mm rain fallen. Well that's not true ofcourse.
But when I buy the GW2001, I think I will get the same results...?
« Last Edit: February 03, 2022, 09:54:32 AM by BliXem »
Offline Gyvate
« Reply #193 on: February 03, 2022, 10:37:15 AM »
Difficult to say ...
The FineOffset/Ecowitt approach to haptic rain detection is different from (and as it seems more sphisticated than) the Tempest approach. But imo it still needs more testing and improvement of the algorithms used in the firmware.
That's the main purpose of this beta test to collect data from as many as possible scenarios through all variations of possible rainfall situations. I guess (but that's an assumption only) that the medium, strong and very strong scenarios (in all their variations) are already pretty well covered.
Where it needs more improvement is the very low, low through medium rainfall range. Whether the ß-test results will end up in a hardware change, I'd rather doubt, but I don't want to exclude it. The hardware basis is already more sophisticated than the Tempest approach [which would detect sonar wave only disturbances like your fighter jets and discard them] and not dependent on neighbour stations for calibration either. (AI cannot do everything  8-) ).
Still, for the time being, if you are in a hurry to get a new station, you are probably better off with a WS80 + WH40 + WH32(-EP) and a matching console of your choice (GW2000, GW1100, HP2551, WN19x0): e.g. the HP2553, GW1103 stations.
Otherwise I would wait for the results of the ß-test and resulting updates in the WS90 firmware before getting me a WS90. But in general the piece is promising.
« Last Edit: February 03, 2022, 10:39:38 AM by Gyvate »
Offline Gyvate
Re: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test
« Reply #194 on: February 03, 2022, 10:45:40 AM »
Just edited the original post/thread name including/encompassing the ß-test which has meanwhile become the main topic in this thread
Offline BliXem
« Reply #195 on: February 03, 2022, 10:48:51 AM »
Thanks for your response! :) Well I will wait then. I want to replace the Tempest and add the GW2001 with the lightning detector. Do you know if one of the two consoles are working with this new weatherstation?
Offline Gyvate
« Reply #196 on: February 03, 2022, 10:55:28 AM »
The FineOffset/Ecowitt approach to haptic rain detection is different from (and as it seems more sphisticated than) the Tempest approach........
The WS90 7-in-1 outdoor sensor array (the station name is GW2001 and it consists of the displayless console/gateway GW2000 and the outdoor array WS90) can be received (so far, firmware updates may increase the number of stations able to receive it also) by the HP2551, GW1000, GW1100, GW2000, HP350x and WN19x0 consoles.
And they can all receive the signal of the WH57 lightning detector.
See also our matrix at
https://www.wxforum.net/index.php?topic=40730.0
which we try to keep up-to-date as real-time as possible.
Offline BliXem
« Reply #197 on: February 03, 2022, 11:08:53 AM »
Aight, thanks! Like the Tempest, there is no accurate forcasting (not based on the barometer) right?
Offline Gyvate
« Reply #198 on: February 03, 2022, 11:14:29 AM »
a) the GW2000/GW1x00 are diplayless consoles and gateways
b) the WN19x0 consoles (x=0 "black" and white, x=1 coloured display) are rather cheap but do NOT show solar radiation and UV
c) the HP2551 is the flagship, big, coloured display which also shows weather forecast based on barometric observations
for a picture of the main display: https://www.wxforum.net/index.php?topic=40730.0
page down to HP2551 console
« Last Edit: February 03, 2022, 06:08:50 PM by Gyvate »
Offline Gyvate
« Reply #199 on: February 04, 2022, 03:23:07 AM »
last line will be updated towards end of the day
