Author Topic: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test  (Read 16135 times)
Online olicat
  • GWxx00, HP2551C, HP3501C, WN1900C & FOSHKplugin
    • FOSHKplugin
Re: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter
« Reply #150 on: January 21, 2022, 11:46:07 AM »
Hi!
can GW1000 and GW2000 connect to the same WiFi router at the same time?
I did not test this yet but why not?
Here are 2 GW1000, 1 GW1100 a HP3501 and a HP2551 all in the same WIFI.
Where do you expect problems?
Oliver
Offline Rover1822
« Reply #151 on: January 21, 2022, 11:54:21 AM »
I can't imagine there being an issue, network protocol just doesn't work that way.
Ambient:WS-2000,PM 2.5 x2,WH31B x2,WH40E,WH31P
EcoWitt: GW1100,GW1000 x4,WH31 x2,WH57,WH51 x12, WH40,WH5360B,WN34S,WittBoy
Web Sites: WU, Ambient Weather , Ecowitt.net , Ecowitt.net (TEST)
Personal Sites: Weather Cam
Offline hiljolodewijk
    • Weerstation Marsdijk
« Reply #152 on: January 21, 2022, 12:35:52 PM »
Out of curiosity can GW1000 and GW2000 connect to the same WiFi router at the same time?
This works without problems (in my case).
Offline tweatherman
« Reply #153 on: January 21, 2022, 04:41:47 PM »
Thanks...I was just curious if anyone has had any issues.
tweatherman
Offline KC5JIM
    • KC5JIM Weather
« Reply #154 on: January 21, 2022, 05:27:01 PM »
tweatherman
Yes. You can connect as many of each as you want and each will have a unique IP address.
Ecowitt Wittboy| FOSHKplugin on Pi 4
Offline Gyvate
« Reply #155 on: January 21, 2022, 05:42:04 PM »
tweatherman
Not quite - this depends on the size of your subnet  \:D/ - minus the number of other devices in your network.  8-)
But virtually, for (most) practical purposes, as many as you want ...
Froggit WH4000SE (=EW 2320E) 1.6.4/GW1100 2.1.4/Froggit DP1500 1.6.8 (+EW GW1000 (4) 1.6.8/7.2 test/backup)/HP1000SE Pro (HP2551) 1.6.4/1.7.8, WH2650 WiFi (2) 1.7.2,GW2000 2.1.4;
Ecowitt WS90-,WS80,WH40,WH65,WH31(5),WH31-EP(1),WN30/DP30 (1),WH32(1),WH32-EP(1),WH32B [T/H/P] (1), WH57 [Lightning] (1), WH41 [PM2.5] (2), WH51 [SoilMoisture] (5), WH45, WH55 (2)
MeteobridgePro(2)[test,prod 5.4 May 07 2022, 14745 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/CumulusMX 3184/MB RPi4(2671)
Barani Meteoshield Pro, MetSpec Rad02
Ecowitt 5763,34418;WU ISAARB3(WH4000SE), ISAARB22(HP2553), http://meshka.eu
Offline KC5JIM
    • KC5JIM Weather
« Reply #156 on: January 21, 2022, 05:53:19 PM »
tweatherman
Setup a /16 subnet and help yourself to up to 65,534 devices. I think, for all practical purposes, that qualifies as unlimited.
Offline Gyvate
« Reply #157 on: January 21, 2022, 06:05:16 PM »
tweatherman
Why so humble ?   :?:  Only /16 ...  :roll: I'm disappointed  :shock:- why not /12 or /8 ??  (even though usual private subnets are /24 and "bigger" number = smaller).
« Last Edit: January 21, 2022, 06:07:28 PM by Gyvate »
Online olicat
    • FOSHKplugin
« Reply #158 on: January 21, 2022, 06:18:10 PM »
Hi!
In fact, I ran into serious problems recently with my DHCP range of 55 addresses (I work a lot with static addresses). Precisely because no more free address was available!
Unfortunately, I can not assign a static address with the Ecowitt devices - so I had to increase my DHCP range significantly.
But I also only use a 24 network here. Time for change?
Oliver
Offline Gyvate
« Reply #159 on: January 21, 2022, 06:29:37 PM »
The DHCP range was one issue I ran into when pairing a GW1000/WH2650 console; the console wouldn't pair as it wouldn't receive an IP address from the DHCP server in the router - but this range can be changed. 252 addresses in a 255.255.255.0 (or /24) subnet (255 - standard addresses for gateway(s), broadcast etc.) should be enough in most private networks and the DHCP range can be set from e.g. 150-250, usually enough for devices which need an IP address via DHCP. The new GW2000 can finally have a static IP assigned. [tup]
Online olicat
    • FOSHKplugin
« Reply #160 on: January 21, 2022, 06:52:04 PM »
Hi!
Nice!
Thanks for info and thanks to LAN-port!
Or is the WIFI port also configurable to static address?
Oliver
Offline Gyvate
« Reply #161 on: January 21, 2022, 07:09:49 PM »
No, only the Ehternet port eth0.
« Last Edit: January 21, 2022, 07:14:45 PM by Gyvate »
Offline tweatherman
« Reply #162 on: January 21, 2022, 08:04:10 PM »
Running into a problem with GW2000 is uploading to Ecowitt.net but the app keeps switching IP addresses 192.168.1.4 to 192.168.1.00. Do I need to change the default gateway IP address in the GW2000 setup page in order to be able to talk to the GW2000 via the app?
Update: I got it working by changing the default gateway IP address.
tweatherman
« Last Edit: January 21, 2022, 08:17:56 PM by tweatherman »
Offline giusCB
« Reply #163 on: January 24, 2022, 11:40:41 AM »
first rain-data show a massive underestimate but i'm to be honest ...so far I have not seen a single installation done well. To test the rain gauges they must be on the same level and not in different positions and with a good manual rain gauge as reference.
Offline Gyvate
« Reply #164 on: January 24, 2022, 11:46:33 AM »
maybe you are blind  #-o - or didn't look properly  ;) - my installation is WS90 and WH40 levelled and at the same height above ground, and I have two manual rain gauges in place.
I posted a picture of the WH40/WS90 setup - and commented that the picture perspective might give the idea that they are not at the same level - but they are.
So I think I'm well set.
Maybe it's the Italian English  ;) - you might want to explain what exactly you mean by "installation done well" (or not done well). Do you mean "set up" or do you mean the performance of the rain gauges ...
« Last Edit: January 24, 2022, 11:48:49 AM by Gyvate »
Offline Autofill
« Reply #165 on: January 26, 2022, 11:08:32 AM »
just got my updated order email now showing that I purchased the PowerPack (plus the GW2001) with 2 items total. It doesn't show the bird spike gift though. Anyone get all the items, yet?
Ecowitt WH2320-E
Ecowitt HP2551-C
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH41 (Honeywell-based USB/Supercap modified)
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Ecowitt Wittboy running on 12VDC  solar power
Offline giusCB
« Reply #166 on: January 27, 2022, 08:07:05 AM »
Another test today with very light rain, in nederland   :?
Wh40
Ws90
-47%
« Last Edit: January 27, 2022, 08:08:41 AM by giusCB »
« Reply #167 on: January 27, 2022, 08:10:49 AM »
Hey, thats my data! :shock: ;)
I summarized it in one graph. As you can see, the WS90 'misses' quit a lot of rain (dark blue is WS90, light blue is WH40 as a reference). IMO it isn't sensitive enough (WH40: 1.9mm, WS90: 1.0mm).
« Last Edit: January 27, 2022, 08:12:21 AM by hiljolodewijk »
Offline giusCB
« Reply #168 on: January 27, 2022, 08:11:46 AM »
I summarized it in one graph. As you can see, the WS90 'misses' quit a lot of rain. IMO it isn't sensitive enough (WH40: 1.9mm, WS90: 1.0mm).
Much better this graph
Thank you for the data  [tup]
Offline Gyvate
« Reply #169 on: January 27, 2022, 08:31:19 AM »
in my current situation, temperatures around the freezing point, and a slight drizzle, my WS90 shows 0.3 mm rainfall while the WH40 shows nothing - probably frozen.
I just climbed up and made a visual check:
there is a little ice lump at the of the debris protection spiral. Also, the surface of the funnel is covered by tiny droplets which will probably evaporate in the wind before forming a bigger drop and can be counted.
Looks like this situation is managed better by the WS90 than by the WH40. A few days ago in stronger drizzle the WS90 and the WH40 came up with the same result (0.7 mm) at the end of the day, but the distribution over time was very different for both sensors.
links:
https://www.ecowitt.net/home/index?id=27607 - HP2551 + WH40
https://www.ecowitt.net/home/index?id=73231 - GW2000 + WS90
At a third occasion the WS90 underperformed by a few 1/10 of mm.
Stronger and longer rain didn't occur yet.
Also not strong and very strong rain where the WH40 starts underperforming significantly.
Offline box
« Reply #170 on: January 27, 2022, 08:43:44 AM »
links:
presumably a solution night be a situation where each corrects for the other depending on the context?
So where would that algorithm be? Within ecowitt net?
Offline giusCB
« Reply #171 on: January 27, 2022, 09:40:12 AM »
but the good news is the rain rate very similar,  it's a good base on where to work
Offline giusCB
« Reply #172 on: January 30, 2022, 06:01:13 AM »
good performance today !!  [ You are not allowed to view attachments ]
Offline giusCB
« Reply #173 on: February 01, 2022, 04:33:20 AM »
another days of rain, thanks hiljolodewijk for the graph. in italy the beta test datas are private, we cannot read  :lol:
« Reply #174 on: February 01, 2022, 06:05:37 AM »
Haha I don't need to update you guys anymore. Giuseppe does all the work =D>
For anyone interested, I made a page where all measurements of the WS90 are compared to the other sensors (WH32 temp/hum and WS40 rain and WS80 wind):
https://www.weerstationmarsdijk.nl/ws90beta.php (for the graps from 0.00 AM till now)
https://www.weerstationmarsdijk.nl/ws90beta.php?interval=24 (for 24 hour lookback)
