Author Topic: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test  (Read 39677 times)
Offline tweatherman
Re: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter
« Reply #125 on: January 17, 2022, 04:20:28 PM »
here a few pictures of the GW2000 gateway ...
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
the text under the LEDs is blurry but even the normal print is not very clear
Blue: sensor link    red: server
diameter is 11 cm (4 inches)
Thanks for the pics.
Interesting that GW2000 looks like it has a 3in1 probe with it. I was under the assumption that I needed to order the WH32 indoor sensor with the 2551 display console so I have both coming.
WH32 will be useless to display on the console then since I’m sure the sensor from the GW2000 will take presidency for indoor conditions on console?
tweatherman
« Last Edit: January 17, 2022, 04:24:16 PM by tweatherman »
Offline Gyvate
« Reply #126 on: January 17, 2022, 05:06:09 PM »
The GW2000 console has inbuilt T/H/P sensors. When you say WH32, you probably mean a WH32B T/H/P indoor sensor combo (as the WH32 is the outdoor T/H sensor). For the HP2551 console the WH32B T/H/P indoor sensor is needed as the HP2551 console doesn't have an inbuilt indoor T/H/P sensor.
The GW2000 console and the HP2551 console are completely independent from each other - they can both receive the WS90 7-in-1 array. (HP2551 with device firmware 1.7.7). The HP2551 can receive a WH32B, but the HP2551 cannot receive the readings of the GW2000 inbuilt T/H/P sensor(s). And the GW2000 (GW1100) cannot receive a WH32B.
« Last Edit: January 17, 2022, 05:17:56 PM by Gyvate »
Offline tweatherman
« Reply #127 on: January 17, 2022, 05:38:33 PM »
Thanks fo the clarification on this Gyvate. I would have thought Ecowitt would have the GW2000 3in1 inside probe communicate to the 2551 display console.
tweatherman
Offline tweatherman
« Reply #128 on: January 17, 2022, 07:11:53 PM »
Got my notification to send my info (address etc) , which I did , to Ecowitt for the Kickstarter flash sale. I did at the same time while supporting the flash sale , add addons, will be interesting if they show up.
I have to say they did provide very good instructions for those that are getting it from kickstarter. I was impressed.
I just sent in my information as well. I'm also expecting the power supply add on.
Thanks for the clarification on the shipping.
tweatherman
Offline Gyvate
« Reply #129 on: January 18, 2022, 04:56:10 AM »
https://www.ecowitt.net/home/index?id=73231
But the/my WS90 and the/my WH40 cannot be shown on the same dashboard - they are mutually exclusive.
Another observation:
the (GW1000) API of the GW2000 cannot be queried via the Ethernet IP address - only the WLAN interface works for that purpose. My weewx crashed with the eth0 address not receiving a response, while with the wlan0 address it works properly.
https://www.ecowitt.net/home/index?id=73231 GW2001 = GW2000 + WS90
https://www.ecowitt.net/home/index?id=27607 HP2553 = HP2551 + WS80 + WH40
light rain forecast for tomorrow, day after tomorrow here - let's see what it gives
regarding the GW2000 ethernet interface - I have posted a suggestion for making it fully functional in the ecowitt.com forum (post still under revision by their forum admins)
EDIT: my router and the GW2000 seem to have tricked me - using a different static IP address for my GW2000 made it working - so it looks as if the eth0 interface is fully functional.
« Last Edit: January 18, 2022, 11:52:34 AM by Gyvate »
Offline giusCB
  • www.turismometeo.it
« Reply #130 on: January 18, 2022, 07:31:56 AM »
But the/my WS90 and the/my WH40 cannot b e shown on the same dashboard - they are mutually exclusive.
https://www.ecowitt.net/home/index?id=34418 HP2553 = HP2551 + WS80 + WH40
On the dashboard I read Wh65, not WH40. Is correct?
www.turismometeo.it
Offline Gyvate
« Reply #131 on: January 18, 2022, 11:50:39 AM »
There was a copy-and-paste error - I corrected the link in the post above
Offline giusCB
« Reply #132 on: January 18, 2022, 12:02:08 PM »
thank you very much, can we see a photo of the setup?
www.turismometeo.it
Offline Gyvate
« Reply #133 on: January 18, 2022, 12:03:51 PM »
As soon as my bi-furcated mast end arrives and both the WH40 and the WS90 are mounted, yes !  :-)
Offline Mandrake
« Reply #134 on: January 18, 2022, 12:16:40 PM »
I quite like the GW2000, its like a little UFO is on the desk.
At night time the plastic is semi transparent and the whole thing glows a light blue!
I'll post a photo of my WS90 on its mount tomorrow when I get a chance. I meant to take a photo today but was rushing around trying to keep on top of work calls and e-mails at the same time as playing with the GW2000 and WS90!
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline Rover1822
« Reply #135 on: January 18, 2022, 12:53:27 PM »
You know people are going to complain about it glowing and obstructing something , or being annoying...  :-P
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline box
« Reply #136 on: January 18, 2022, 12:57:44 PM »
How about some gentle pulsing or flashing...... [tup]
Offline Gyvate
« Reply #137 on: January 18, 2022, 12:59:25 PM »
not to forget the hidden levitating feature ...  \:D/
Offline box
« Reply #138 on: January 18, 2022, 04:18:24 PM »
...and suitably ethereal sound effect..... :-"
Offline Mandrake
« Reply #139 on: January 19, 2022, 06:21:06 AM »
Here's a rather poor photo of the WS90 amongst my other Ecowitt sensors.
The lens has made it all appear flat so I will try and get a better photo later.
No rain yet so unable to draw any comparisons and wind speeds comparable to WS80 but only light winds so hard to draw any conclusions.
G1ZFO
Offline Gyvate
« Reply #140 on: January 19, 2022, 12:34:23 PM »
my setup ...
WH40 and WS90 on one level to make rain readings comparable
WH65/WS69, WS80 also visible
they may only look tilted on the photo - their are levelled  8-)
Some drizzle has started - first readings coming in  :-)
« Last Edit: January 19, 2022, 12:37:12 PM by Gyvate »
Offline Rover1822
« Reply #141 on: January 19, 2022, 01:06:22 PM »
No concern about certain readings being influenced by the obstruction of other sensors so close?
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline davidefa
« Reply #142 on: January 19, 2022, 01:07:27 PM »
@Mandrake
Seems you received the wrong sensor, it should be FattBoy ( the cousin of WittBoy )
Offline Gyvate
« Reply #143 on: January 19, 2022, 01:21:39 PM »
Maybe the perspective gives a wrong impression - the distance (horizontally - projected on the ground) is imo sufficient
The distance e.g. between WH40 and WS90 is 1.25 m (49 inches)
« Last Edit: January 19, 2022, 01:26:50 PM by Gyvate »
Offline giusCB
« Reply #144 on: January 19, 2022, 03:51:17 PM »
The reference is the ws65?
www.turismometeo.it
Offline Mandrake
« Reply #145 on: January 20, 2022, 03:40:48 AM »
Yes, the Tri-Wing WH65 is the prime reference for wind and rain.
However I have more than one GW1000 so I can compare the WS80 wind readings with the WS90 also!
Unfortunately at present we are right under high pressure and so very benign calm weather for some time.
G1ZFO
Offline giusCB
« Reply #146 on: January 20, 2022, 04:49:43 AM »
the wh65 overestimate by +25%. Remember to set an offset on rain gauge
www.turismometeo.it
Offline Gyvate
« Reply #147 on: January 20, 2022, 05:49:27 AM »
The 25% don't show in my weewx database where the real floating point values (multiples of 0.254 mm) are stored and not the rounded values on the console and maybe also on the graphs. My WH65 readings (weewx) match pretty well with two manual rain gauges. Observed that for some time. And, it depends very much on the type and amount of rain plus the rain rate per minute (not per hour, not reliable). With drizzle and little rain my WH65 rather underreads.
But I don't want to open a can of worms here ...  8-)
Offline giusCB
« Reply #148 on: January 20, 2022, 05:50:14 AM »
 [tup] [tup]
www.turismometeo.it
Offline tweatherman
« Reply #149 on: January 21, 2022, 11:43:44 AM »
Out of curiosity can GW1000 and GW2000 connect to the same WiFi router at the same time?
tweatherman
