Author Topic: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test  (Read 15745 times)
Offline Gyvate
Re: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter
« Reply #100 on: January 15, 2022, 04:23:37 AM »
Just curious if anyone has insight to what temp/hum. sensor will be in the new station?
tweatherman
The standard sensor will be sht40 ( the upgrade version of sht30). However it will be a sensor with sht35 sensor available for accessory part: it can be plug and play type, and it is easy to make this upgrade or change at user side if they want to have a better sensor.
Do you mean like an external WH32-EP or as a replacement inside the WS90 unit ?
Froggit WH4000SE (=EW 2320E) 1.6.4/GW1100 2.1.4/Froggit DP1500 1.6.8 (+EW GW1000 (4) 1.6.8/7.2 test/backup)/HP1000SE Pro (HP2551) 1.6.4/1.7.8, WH2650 WiFi (2) 1.7.2,GW2000 2.1.4;
Ecowitt WS90-ß,WS80,WH40,WH65,WH31(5),WH31-EP(1),WN30/DP30 (1),WH32(1),WH32-EP(1),WH32B [T/H/P] (1), WH57 [Lightning] (1), WH41 [PM2.5] (2), WH51 [SoilMoisture] (5), WH45, WH55 (2)
MeteobridgePro(2)[test,prod 5.4 May 07 2022, 14745 - Blake-Larsen Sun Recorder - RPi4/weewx 4.5.1/CumulusMX 3183/MB RPi4(2671)
Barani Meteoshield Pro, MetSpec Rad02
Ecowitt 5763,34418;WU ISAARB3(WH4000SE), ISAARB22(HP2553), http://meshka.eu
Offline henry
« Reply #101 on: January 15, 2022, 04:30:13 AM »
It's interesting that the solar panel on the weather station I run charges the battery at times when officially, by that WMO definition, there is not a "sunshine" condition.
Rich K.
How do you tell at which amount of solar radiation exposure the super-capacitor starts being charged ?
If it's a really good one (S-C), then it charges at low wattage/area.
What outdoor array do you have ?
Because, in fact, the batteries of the WH65/WS69, WS80, WS68 arrays (the Ambient WS-2000/5000/2902 outdoor arrays) are not charged. What is charged is a super-capacitor which can run the "station" (the outdoor sensor array - station = console + sensors) up to two days when not being reloaded after having been fully charged. It's only then that the batteries come in as a backup. This only occurs at special conditions (long[er] time not sufficient sun exposure, very cold - like during polar night as an extreme case).
Still, it would be interesting to know what minimum amount of wattage/m2 of global radiation is needed for the S-C to start being charged.
The solar level is not the point: when like 50w/m^2 radiation is there, it started charging the super cap but just with much less charging current, like 1mA or even less. So usually during the day, it takes about 2 ~ 3 hours to complete the supper cap recharging. But when the solar panel efficiency is getting less, then it will take a longer time to charge. But as long as the supper cap can be refilled up fully, then it should be fine.
On WS90, the super cap is twice bigger compared to ws80.  During rainy times, the rain circuit consumes like a 1.5mA current on average, so if it rains for months, then the battery power will be surely used.  There is a voltage meter same as ws80 on the dashboard, and it can be programmed to send an alert email for taking precautious actions.
Offline henry
« Reply #102 on: January 15, 2022, 04:33:20 AM »
tweatherman
EP sensor is too big, and it is not possible to be fit inside the shielding.  So we just hav the sensor changed to sht35 on the same sensor board. if it is needed, however, we can still make the sensor to be the same as the wh32 EP sensor: place it outside the sensor array. which way do you prefer?
Offline Gyvate
« Reply #103 on: January 15, 2022, 05:04:59 AM »
tweatherman
I think you answered my question - it's a replacement in the unit.
As for the WH32(-EP), I expect it to be useable as it can be done today, in the GW1x00, GW2000, HP2551 consoles I can activate it as a T/H sesnor and the console will prefer its readings over the WS90 inbuilt sensor. For an optimal placement for an outdoor temperature sensor a separate T/H sensor is anyway better.
As for the WH32-EP/WH31-EP in general, Ecowitt should think about offering two versions:
One with the cable length as is (1 m) and one with an extended cable length of two meters (as 1 m is often too short for a good placement of the sensor body).
« Last Edit: January 15, 2022, 05:11:19 AM by Gyvate »
Offline mauro63
« Reply #104 on: January 15, 2022, 06:15:59 AM »
tweatherman
Sensirion sht30 but ready for future upgrade
M.
Ciao Mauro. Are you sure?
The newest ws80 has the sht40, there is also a firmware update for this sensor https://osswww.ecowitt.net/uploads/20211223/WS80%20Upgrade(v1.2.0)%20Tool%20Kit.zip
Sorry, my mistake :(
M.
Offline tweatherman
« Reply #105 on: January 15, 2022, 03:30:18 PM »
Just curious if anyone has insight to what temp./ hum. sensor will be in the new station?
tweatherman
I was referring to stock oem temp.hum sensor inside the WS90 unit. What is the better sensor SHT35 or the SHT40?
tweatherman
« Last Edit: January 15, 2022, 03:31:52 PM by tweatherman »
Offline Gyvate
« Reply #106 on: January 15, 2022, 03:36:31 PM »
the SHT40 is a newer version of the SHT30
the SHT35 is still more accurate - its correspondant new version would be the SHT45
Also, the SHT3x series is meant for industrial use, the SHT4x series for consumer electronics
« Last Edit: January 15, 2022, 03:43:33 PM by Gyvate »
Offline tweatherman
« Reply #107 on: January 15, 2022, 03:41:15 PM »
Thanks Gyvate.
tweatherman
Offline tweatherman
« Reply #108 on: January 15, 2022, 10:06:13 PM »
Delivery scheduled for today 10 am (in about 2 hours). But 10 days out for holidays  #-o
So I'll have to wait before I can see/test it.. :-(
Have any idea who the carrier will be for delivery of this unit? I’m thinking perhaps postal service.
tweatherman
Offline Gyvate
« Reply #109 on: January 16, 2022, 03:34:56 AM »
This depends on where you are located. The delivery into your country will be handled by Yun Express Logistics. The last mile carrier will depend on your location/country and with whom Yun Express have a cooperation - in Europe this is mainly DHL.
Offline hiljolodewijk
    • Weerstation Marsdijk
« Reply #110 on: January 16, 2022, 03:39:26 AM »
Yes, my WS90 was delivered yesterday with DHL (Netherlands)
Offline Gyvate
« Reply #111 on: January 16, 2022, 03:41:30 AM »
To be precise, it was most likely not only a WS90 but a GW2001, a WS90 plus the GW2000 gateway.  8-)
« Reply #112 on: January 16, 2022, 03:44:33 AM »
Haha I don't know! I'm a week on holidays, and it was delivered yesterday, the first day that I'm not at home since months  #-o
Offline Gyvate
« Reply #113 on: January 17, 2022, 09:38:12 AM »
My set arrived today. Unpacked - found that the charger plug for the GW2000 was UK type and not useable. I used a charger plug from one of my smart phone instead.
The GW2000 comes with an Ethernet port which made it (for me) easy to set it up.
It seems to be, however, that the Ehternet port is not used for posting data.
Data at ecowitt.net would only arrive after the WiFi/WLAN interface was activated. Before it showed offline - even though one minute posting was set.
It might still be a coincidence. If not, posting via the Ethernet port should be enabled !!
The web interface is the same as for the GW1100, only the firmware revision of the GW2000 is 2.1.0.
Offline giusCB
« Reply #114 on: January 17, 2022, 09:52:52 AM »
can you post the link to see the data online of the ws90 ? do you have a reference rain gauge for comparing the data?  [tup]
Offline Gyvate
« Reply #115 on: January 17, 2022, 09:57:04 AM »
https://www.ecowitt.net/home/index?id=73231
But the/my WS90 and the/my WH40 cannot b e shown on the same dashboard - they are mutually exclusive.
Another observation:
the (GW1000) API of the GW2000 cannot be queried via the Ethernet IP address - only the WLAN interface works for that purpose. My weewx crashed with the eth0 address not receiving a response, while with the wlan0 address it works properly.
EDIT: that was some messed up communication between the GW2000 and my router - meanwhile settled - the Ethernet interface works properly (weewx can read data via it).
« Last Edit: January 18, 2022, 11:55:05 AM by Gyvate »
Offline giusCB
« Reply #116 on: January 17, 2022, 10:05:17 AM »
thanks so much! so the ethernet port is disable for now.
to read the wh40 i think you need a separate gw1000-1100. You can turn off the reception of the other sensors in the wsview ID screen
Offline tweatherman
« Reply #117 on: January 17, 2022, 10:33:33 AM »
Crazy how my unit went from the US then to CA then back into the US for my destination in northern Michigan. Timeline is from bottom to top of list.
Arrived at Facility----Louisville
17 2022/01/16 22:02:12
Departed from Facility----Ontario
16 2022/01/15 09:47:10
Arrived at Facility----Ontario
15 2022/01/15 01:54:08
Departed from Facility----Los Angeles
14 2022/01/15 00:51:06
Origin Scan----Los Angeles
13 2022/01/14 15:22:04
tweatherman
Offline Mandrake
« Reply #118 on: January 17, 2022, 10:40:19 AM »
I have mine sitting on the kitchen table now.
Will try and get deployed to my mast next to the WS80 tomorrow if work permits.
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline giusCB
« Reply #119 on: January 17, 2022, 10:53:50 AM »
take some photos  :grin: :grin:
Offline Gyvate
« Reply #120 on: January 17, 2022, 01:14:38 PM »
here a few pictures of the GW2000 gateway ...
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
the text under the LEDs is blurry but even the normal print is not very clear
Blue: sensor link    red: server
diameter is 11 cm (4 inches)
« Last Edit: January 17, 2022, 01:22:23 PM by Gyvate »
Offline Gyvate
« Reply #121 on: January 17, 2022, 01:16:36 PM »
@giusCB: quite some of my console fleet already report different combinations of my sensors - including the WH40.
So its values are taken care of.
Offline Rover1822
« Reply #122 on: January 17, 2022, 01:20:46 PM »
Got my notification to send my info (address etc) , which I did , to Ecowitt for the Kickstarter flash sale. I did at the same time while supporting the flash sale , add addons, will be interesting if they show up.
I have to say they did provide very good instructions for those that are getting it from kickstarter. I was impressed.
Ambient:WS-2000,PM 2.5 x2,WH31B x2,WH40E,WH31P
EcoWitt: GW1100,GW1000 x4,WH31 x2,WH57,WH51 x12, WH40,WH5360B,WN34S,WittBoy
Web Sites: WU, Ambient Weather , Ecowitt.net , Ecowitt.net (TEST)
Personal Sites: Weather Cam
Offline KC5JIM
    • KC5JIM Weather
« Reply #123 on: January 17, 2022, 03:02:54 PM »
tweatherman
That's Ontario, California
Ecowitt Wittboy| FOSHKplugin on Pi 4
Offline KC5JIM
    • KC5JIM Weather
« Reply #124 on: January 17, 2022, 03:24:37 PM »
I just sent in my information as well. I'm also expecting the power supply add on.
