Author Topic: Switching from Ambient IP Observer to Ecowitt GW1000  (Read 769 times)
Offline OldAlaskaGuy
  • Alaska, The Last American Frontier
  • Living in the "Last American Frontier"
« on: November 19, 2021, 07:13:39 PM »
I am currently reporting to CWOP/MADIS through Ambient/CWOP  I would like to use My Ecowitt GW1000 to send this data. Is there a way to do this and keep my existing station identifiers?
Offline Platokidd
  • top side land of Lincoln
« Last Edit: November 19, 2021, 08:17:02 PM by Platokidd »
Ambient
1-WS-5000 1-WS-2902A 2-WS40/RAIN 1-WH31L
1-METEOBRIDGE 1-PM2.5 (WH41B) 3-WH31 1-SRX100LX
ECOWITT
2-HP2550 2-HP2560 2-GW2000 2-GW1100
2-WS68 1-WS80 1-WH32EP 10-WH31 1-WH40
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
1- Storm Sensor-Zelda the dog ;)
Re: Switching from Ambient IP Observer to Ecowitt GW1000
« Reply #2 on: November 19, 2021, 08:51:46 PM »
This is what I am using now:   https://i.postimg.cc/hPyB1bk2/observerip.jpg   but I think it may be starting to fail. It is intermittently losing packets. I was hoping to see if there was a way to use the GW1000 although this is the cheapest I have seen these Weather Bridges in quite a while.Using a GW1000/1100 has it's advantage that a lot of Ambient equipment can be used with it.
« Last Edit: November 19, 2021, 08:53:45 PM by Weatheroger »
Offline Platokidd
« Reply #3 on: November 20, 2021, 07:34:04 AM »
Nearing my 2 years with the AW meteobridge. Think it's $100 to continue with updates.
This is why I'm also looking for another way to send to CWOP that is simple.
Since the last update of the AW Meteobridge I am having some issues with iit sending to AW dot net. Not much response on the boards but you can have a look. It still works fine for sending to cwop and other places.
https://www.wxforum.net/index.php?topic=42952.0
« Last Edit: November 20, 2021, 07:38:00 AM by Platokidd »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline WA4OPQ
  • 4 stations: 2902 array, GW1000, 3 on Meteobridge
« Reply #4 on: March 03, 2022, 04:37:52 PM »
I'd recommend getting a raspberry pi (if you can) and run WeeWx.
WeeWx has an extension to receive data from the GW1000, then WeeWx will send to CWOP.
Offline 1davidbrock
« Reply #5 on: March 03, 2022, 06:40:29 PM »
Why not ask CWOP?  They have always been helpful to me.   cwop-support@noaa.gov
WS-2902A | Ecowitt GW1000 | Meteobridge (D-Link DIR-505)
WU: KTXSUGAR156  |  PWSweather: KTXSUGAR156
CWOP: FW5473  |  Meteomap:  FW473
AWEKAS: 15930
