Author Topic: Can you tell the barometric pressure from your food  (Read 796 times)
Offline DaleReid
    • Weather at Eau Claire, WI
« on: September 12, 2021, 01:56:56 PM »
Or, at least when your food was packaged and sealed?
I think that commercial aircraft are pressurized to 8,000 foot level when actually much higher, but clearly a lower pressure than sea level.  I recall back when I did fly and you either got a bag of something like chips or pretzels for 'free' or bought one, the little bags were blown up light air pillows.
Today I was going to make a quick cup of coffee and turned on the Keurig machine we have in the corner.  I had recently bought a box of the flavor we like, and got one out.  The top was sort of sucked in a bit.  Coffee was very good, but I recall usually seeing the top seal of aluminum foil puffed out, as if processed and sealed at a lower altitude.
The coffee, of course, is stored and brewed at a constant altitude, but I'm thinking after looking at the whole box that all were sealed at the same time (slightly sucked in) and peaked at another box from another purchase and there was the slight pillowing of the top of the container, so it wouldn't be subject to the extreme altitude changes that I noticed with the airplane cabin.
Are there any other packaging expansions that I've not paid enough attention to in order to notice this effect?
Just curious.
Dale
ECWx.info
ECWx.info/t/index.php
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
Re: Can you tell the barometric pressure from your food
« Reply #1 on: September 12, 2021, 02:08:14 PM »
Have you ever moved K-Cups from warm to cold and back to see if the lid goes up or down?
Offline DaleReid
« Reply #2 on: September 12, 2021, 02:29:04 PM »
Not yet, but heading to the kitchen and will report back in a bit!
Thanks for the idea.
ECWx.info
« Reply #3 on: September 12, 2021, 05:22:42 PM »
I can tell the pressure some foods put on the inside trying to get out
Peanuts on an airplane. Bags change inflation with altitude changes
Offline Aardvark
    • turned off
« Reply #4 on: September 12, 2021, 05:23:13 PM »
Yes they do tend to pook out.
