Author Topic: Use bearing zero when calm?  (Read 1159 times)
Offline Rickoo
« on: August 04, 2021, 01:27:38 PM »
New user here. I've been playing with some of the station settings common options and turned on Use Bearing Zero When Calm. Okay, now I see what that does. However, now it won't turn off? Tried saving, stopping cumulus and re-starting it several times with no luck. How do I turn this back off?
Online PaulMy
Re: Use bearing zero when calm?
« Reply #1 on: August 04, 2021, 02:33:01 PM »
Did you perhaps forget to press [Save] at the bottom.
Mine changes fine if [untick] then [Save], and then back to [tick] [Save].
You can check your Cumulis.ini file for
UseZeroBearing=1 or
UseZeroBearing=0 with 1 = turned on and 0 = turned off.
Enjoy,
Offline Rickoo
« Reply #2 on: August 04, 2021, 02:41:40 PM »
Thanks Paul, how do I view the .ini file?
Online PaulMy
« Reply #3 on: August 04, 2021, 03:13:44 PM »
It is in your \CumulusMX folder \CumulusMX\Cumulus.ini and can be opened by a good text editor.
It has all the settings that you have set through the Dashboard Settings, and will be updated by CMX as you enter new settings and [Save].  It will also be saved whenever you stop CMX, and that will then have current settings for CumulusMX restart.
Some items in Cumulus.ini can be edited by a text editor like Notepad++ and only with CumulusMX stopped, but generally anything that can be done through the Dashboard Editor should be done there to avoid any chance of it being overwritten at a CMX stop.
Enjoy,
Offline Rickoo
« Reply #4 on: August 04, 2021, 03:19:11 PM »
Thanks for the help. Sorry to be such a pita. lol
btw, I definitely saved after making the change.
So, what would be the command to enter in Putty?
Online PaulMy
« Reply #5 on: August 04, 2021, 05:01:09 PM »
Sorry, I can't help with that at all.
Posting on Cumulus forum may get you some answer on that.
Enjoy,
Offline Rickoo
« Reply #6 on: August 04, 2021, 05:23:35 PM »
It's ok. Been reading up on linux. Definitely appears to be something one needs to have a grasp on to work with cumulus and a raspberry pi.
Thanks Paul
