Author Topic: Wet Bulb Globe Temperature  (Read 585 times)
Offline marshad
« on: July 17, 2021, 08:35:19 AM »
Wet Bulb Globe Temperature (WBGT) is an important indicator of heat stress and is used by the military, sports and occupational health authorities. More info here: https://en.wikipedia.org/wiki/Wet-bulb_globe_temperature.
It needs a black globe thermometer to be measured accurately as it takes into account solar radiation, sun position and wind speed as well as temperature and humidity. I have tried to create a program in python to simulate WBGT using standard weather station data. The main source for the maths is here: https://www.weather.gov/media/tsa/pdf/WBGTpaper2.pdf. (I don't pretend to understand all the maths!)
import math
from math import log
from math import atan
from math import exp
from math import cos
from math import radians
# Temperature in C
# Humidity in %
# Pressure Sea Level in mbars
# WindSpeed in Km/h
# SolarRad in w/m3
# SunAltitude in degrees above horizon
# Cloudcover in %
# Enter the data
Temperature = 29.7
Humidity = 27
Pressure = 1014
WindSpeed = 0
SolarRad = 780
SunAltitude = 45
Cloudcover = 0
T = Temperature
RH = Humidity
P = Pressure
W = WindSpeed
S = SolarRad
Alt = SunAltitude
f = Cloudcover
u = W * 1000
if u == 0:
    u = 500
z = radians(90 - Alt)
a = 17.368
b = 238.88
g = log(RH/100) + ((a*T)/(b+T))
# Calculate Dew Point DP
DP = (b * g)/(a-g)
# Calculate Wet Bulb WB
WB = T * atan(0.151977 * (RH + 8.313659)**0.5) + atan(T + RH) - atan(RH - 1.676331) + 0.00391838 * RH**1.5 * atan(0.023101 * RH) - 4.686035
ea = exp(17.67 * (DP - T)/(DP + 243.5)) * (1.0007 + 0.00000346 * P) * 6.112 * exp(17.502 * T / (240.97 + T))
eb = 0.575 * ea**0.142857
fdif = (100 - f)/100
fdb = 1 - fdif
B = S * ((fdb / ((4*(5.67*10**-8)) * cos(z))) + (1.2/(5.67*10**-8)) * fdif) + eb * T**4
C = (0.315*u**0.58)/(5.3865*10**-8)
# Calculate Globe Temperature GT
GT = (B + C * T + 7680000)/(C+256000)
# Calculate Wet Bulb Globe Temperature WBGT
WBGT = 0.7*WB + 0.2*GT + 0.1*T
print(round(WBGT, 2))
Has anybody else tried to do this?
Does anybody have access to real WBGT data to test it?
The program is running live on my site using my own data (in the Temperature box)
http://moonappreciationsociety.com/Meteo/VillarPerosa/index.php
Offline SteveFitz1
    • Tyler Texas Weather
Re: Wet Bulb Globe Temperature
« Reply #1 on: July 17, 2021, 08:55:56 AM »
I created a WBGT page on my site a couple of years ago using PHP. You can see my page here:
https://www.tylertexasweather.com/wbgtforecast.htm
I use a page on the NWS site to compare my results to. They are very close.
https://www.weather.gov/tsa/wbgt
Steve
Offline marshad
« Reply #2 on: July 17, 2021, 12:37:33 PM »
Thanks Steve
What are you using to calculate WBGT?
Can you share the code?
Offline SteveFitz1
« Reply #3 on: July 18, 2021, 11:39:51 AM »
Check your messages. I sent you a couple of PMs.
Steve
Offline marshad
« Reply #4 on: July 19, 2021, 07:55:20 AM »
Steve
Thanks -have responded.
