Author Topic: Add additional soilMoist fields to database  (Read 604 times)
Offline TinkerTown
« on: June 27, 2021, 02:37:47 PM »
I am runnin Weewx with the Belchertown skin and I just added a bunch of moisture sensors to my Ecowitt unit. I am having issues getting them to display in the skin and I looked in the database and I only see four fields for the sensors.
| archive_day_soilMoist1
| archive_day_soilMoist2
| archive_day_soilMoist3
| archive_day_soilMoist4
How can I add additional fields up to SoilMoist7?
I don't know much about database management, I was hoping someone would have the commands to enter to add 5,6,7.
Ecowitt GW1000 | WS-2902C |Weewx on Raspberry Pi
WU: KNMLOVIN14  |  PWSweather: PWSLOVNM1
CWOP: FW9112; https://lovingtonweather.com
Offline SnowHiker
Re: Add additional soilMoist fields to database
« Reply #1 on: June 29, 2021, 02:59:12 AM »
Back up your database in case it doesn't work the way you expect, then try:
wee_database --add-column=soilMoist5
wee_database --add-column=soilMoist6
wee_database --add-column=soilMoist7
More info here:
http://www.weewx.com/docs/utilities.htm#wee_database_utility
Offline TinkerTown
« Reply #2 on: June 29, 2021, 06:07:44 AM »
I got it, thank you! I thought I saw somewhere that said you could do that, but my search skills are apparently not that great! That worked, got them up and running, thanks!
Offline Gyvate
« Reply #3 on: June 30, 2021, 05:07:27 AM »
EDIT: removed as the OP got a solution working ....
« Last Edit: June 30, 2021, 05:44:40 AM by Gyvate »
Offline Gyvate
« Reply #4 on: June 30, 2021, 05:32:34 AM »
« Last Edit: June 30, 2021, 05:44:52 AM by Gyvate »
