Author Topic: Ethernet Logger has arrived  (Read 3758 times)
Offline kg4ooz
« on: June 24, 2021, 11:14:20 PM »
My ethernet logger came in the mail today.  I am very excited to have it up and running.
I do have a minor issue or suggestion on future models.  I opted to power my logger with USB C via a POE breakout box.  The back plate with the mounting holes it so close to the usb connector that I could not fit my plug.  I simply used the supplied cover board as a spacer instead.  It gave me just enough clearance to plug in the usb connector.  Only a minor issue and not really sure how it could be solved.  I love the fact that I can power my console and logger with a single ethernet cable though.
I also noticed that a newer firmware was available on the wifilogger webpage, but I do not see a option to do a firmware update from the web interface.  Could someone possible point me in the correct direction?
I am also having a minor issue with cumulus which I will post in that section of the forum.
« Last Edit: June 24, 2021, 11:18:26 PM by kg4ooz »
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
Re: Ethernet Logger has arrived
« Reply #1 on: June 25, 2021, 05:49:35 AM »
Don't mix up WiFi Logger and Ethernet Logger firmware.
During prototype, firmware update was done using FT Prog program to install it.
Your Ether Logger should have latest version I would expect.
Offline WiFiLogger
« Reply #2 on: June 25, 2021, 07:13:37 AM »
I have not manual yet. I am working on it.
Firmware update manual will be also avaible.
It is not WiFiLogger. It has no update through web interface.
User has to use USB-C cable and software which comes from MCU producer. STM32CubeProgrammer
- On Ethernet module you have slide switch named "BOOT". Please slide it on the left.
- Then click on reset button.
- Ethernet module should be discovered in Windows as "STM32 BOOTLOADER"
- Run STM32CubeProgrammer software.
- After firmware update please set "BOOT" slide switch on the right and click on reset.
Offline WiFiLogger
« Reply #3 on: June 25, 2021, 07:22:14 AM »
I do believe there will be no issue with Cumulus, which I will be not able to solved with firmware update.
Ethernet logger was tested scrupulously, but there is also place for mistake.
It is said that for full testing there is needed 12 people for 3 months involved in project.
Please report any undesirable behavior. I will take care of it.
Offline WiFiLogger
« Reply #4 on: June 25, 2021, 07:36:52 AM »
I have noticed this issue just after I have dispatched batch to Ryan.
Problem is that USB-C has to be in line with Ethernet cable, becase Ethernet module can be powered from USB socket in router, so both cables will goes throught the same path to Ethernet logger and console.
I could also use longer distances on the bottom, not 3.5mm, but something longer to make place for USB-C plug, but then whole module will become less neat.
After all I will add bottom plate without wings. This wall mount plate will be in set, but default setup will be like this first one on the left:
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #5 on: June 25, 2021, 07:43:08 AM »
I used the programmer on a Windows 7 computer. It works with just a few easy steps. Painless process.
I expect newer Windows etc. will run just fine also.
Offline WiFiLogger
« Reply #6 on: June 25, 2021, 07:45:39 AM »
I have started to answer your questions first. I have forgotten about the most important thing.
You are the very first client for the Ethernet module  :)
I hope, you will enjoyed it.
 UU
Offline kg4ooz
« Reply #7 on: June 25, 2021, 11:35:03 AM »
Thank you for the replies.  Yes my logger was sent with V1.11 firmware and I noticed that v1.12 was available.  I will try to do the update tonight when I get home from work.
I am very pleased with the logger and my issue with Cumulus ended up being a problem with the clock settings on my RaspberryPi.  But everything is working great now, I just have to finished setting cumulus up and get my website back online.
Offline Sylver19
« Reply #8 on: August 22, 2021, 10:13:51 AM »
Bonjour , j'ai téléchargé le logiciel ,mais je n'ai pas de usb1 qui se connecte .
Offline WiFiLogger
« Reply #9 on: August 22, 2021, 05:29:52 PM »
- Please slide switch left.
- If device is powered, please click on reset button. If device is power off, then just plug USB cable. It will start in BOOT MODE.
- After job done please slide switch right and click on reset
** Please note that Ethernet logger has Watchdog Chip. It will reboot device after 3 minutes from pressing RESET button.
So to it will be refind by Windows every 3 minutes. Also you have time window 3 minutes to put new firmware.
Offline Sylver19
« Reply #10 on: August 23, 2021, 01:15:27 PM »
bONSOIR, au port j'ai "no DFU detected "
Offline WiFiLogger
« Reply #11 on: August 23, 2021, 01:27:19 PM »
Do you have any signal from Windows that USB device was connected?
If yes, then please check if driver was installed.
If not, please rotate USB-C plug. In general please check USB-C plug/socket
Offline Sylver19
« Reply #12 on: August 23, 2021, 01:37:22 PM »
oui , windows detecte l'usb , peut etre que le pilote n'est pas installé , comment je fais ?
Offline WiFiLogger
« Reply #13 on: August 23, 2021, 02:00:18 PM »
YouTube 1, or YouTube 2
Offline Sylver19
« Reply #14 on: August 23, 2021, 03:08:30 PM »
J'ai mis à jour le pilote avec zadig car windows 7 ,mais toujours pas dtu detected
Offline Sylver19
« Reply #15 on: September 11, 2021, 06:46:55 AM »
Bonjour ,je n'arrive toujours pas à le configurer ,pas de DFU detecté.
« Last Edit: September 11, 2021, 06:49:57 AM by Sylver19 »
Offline Sylver19
« Reply #16 on: September 19, 2021, 11:41:04 AM »
Bonjour , es que quelqu'un peut m'aider ?
Offline Sylver19
« Reply #17 on: September 20, 2021, 04:20:08 PM »
Bonsoir , j'ai réussi mais je dois mettre quoi dans "File Path"?
Offline Sylver19
« Reply #18 on: September 25, 2021, 07:36:59 AM »
hello ? SOS
Offline johnd
« Reply #19 on: September 25, 2021, 07:59:34 AM »
Unfortunately, there don't seem to be many users here who are able to respond to posts in French - English is the standard language here.
Also: This thread is about the Ethernet logger, but you're asking about a USB connection. I presume that you may be trying to update the firmware on the Ethernet logger via a USB connection? But the firmware in the initial batch of loggers was v1.11 AFAIK and the only enhancement available as yet is to v1.12 and this is only a minor change. So personally I wouldn't worry about updating the firmware for now. There may be further details online of how to perform the update later this year.
Cambridge UK
Offline Sylver19
« Reply #20 on: September 25, 2021, 09:30:17 AM »
Bonjour, j'écris en Français et moi je lis l'Anglais avec traducteur auto , non j'ai bien le nouveau MPE ,j'ai bien fait la mise à jour de la console ok,  il me manque juste  " je dois mettre quoi dans "File Path"?"
https://www.wxforum.net/index.php?action=dlattach;topic=42225.0;attach=50572;image
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #21 on: September 25, 2021, 10:51:45 AM »
I read your post before with translator but did not understand the question.
The File Path is the location of the Firmware File on your computer. Hit the browse button and click the files on your computer to where it is located.
Make note of where it is located ahead of time.
« Last Edit: September 25, 2021, 10:54:06 AM by davidmc36 »
Offline Sylver19
« Reply #22 on: September 25, 2021, 11:25:41 AM »
Bonjour , en cliquant parcourir ,il n'y a rien qui s'affiche ,c'est là le problème.
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #23 on: September 25, 2021, 02:14:51 PM »
Have you dwonloaded the file and unzipped it? This would make a bin file, in a place that you choose while unzipping. When you use the browse button, you click around your computer to find that place. Click on the bin file to choose it for updating the logger.
Offline Sylver19
« Reply #24 on: September 25, 2021, 03:04:37 PM »
le logger est à jour et connecté au pc car  je l'ai dans le gestionnaire des périphériques , mais comme je ne suis pas un pro en informatique pas facile.
