Author Topic: Meteobridge 5.1 (March 1st update) and GW1000 v1.6.6 compatibility **solved**  (Read 2577 times)
Anyone having any data acquisition problems with the latest Meteobridge 5.1 March 1st update and the GW1000 with firmware 1.6.6?
If yes please mention which hardware your Meteobridge is running on.
« Last Edit: March 13, 2021, 01:52:49 PM by docbee »
Re: Meteobridge 5.1 (March 1st update) and GW1000 v1.6.6 compatibility
« Reply #1 on: March 03, 2021, 07:49:44 AM »
I realize it has only been a day and no responses. I'll ask another question..
Has anyone upgraded to GW1000 firmware 1.6.6 and the latest Meteobridge 5.1 March 1st update and everything is working?
Online Gyvate
« Reply #2 on: March 03, 2021, 06:02:13 PM »
 I just updated my test MB Pro to Meteobridge 5.1 (Mar 1 2021, build 14337), FW 1.4.
The live data look OK so far, i.e. all my sensors are visible with reasonable values and update intervals.
If the new WH35 is properly handled by MB is difficult to say as the sensor isn't released yet ...
« Reply #3 on: March 03, 2021, 07:44:49 PM »
My concern was not regarding the WH35. My concern was the possibility that some changes in GW1000 firmware 1.6.6 were not being dealt with properly with MB 5.1 March 1st update.
The fact that you have successfully run GW1000 firmware 1.6.6 and MB 5.1 March 1st indicates that at least for some configurations there is no issue. Thank you for testing.
This leaves this other thread over at the Meteobridge forum with some unanswered questions:
https://forum.meteohub.de/viewtopic.php?p=38538#p38538
Online Gyvate
« Reply #4 on: March 04, 2021, 08:13:24 AM »
couldn't find that thread ... :roll:
« Reply #5 on: March 04, 2021, 08:45:31 AM »
Sorry bad link.
Try this one
https://forum.meteohub.de/viewtopic.php?f=56&t=15582
Offline _John C
« Reply #6 on: March 04, 2021, 08:48:43 AM »
GW1000 with firmware 1.6.5/1.6.6 and Meteobridge (TL-WR902AC v3) FW1.3 V5.1 with March 1st/4th update ; I get no live data on Meteobridge. All works fine with Meteobridge 5.0  [tup]
« Last Edit: March 04, 2021, 08:54:14 AM by _John C »
Ecowitt GW1000CA x2,   HP2551CA,   WH65 Outdoor 7in1 2 arm array,  WH32B Indoor Temp/Hum/Baro, WH45 Co2/PM2.5/PM10,  WH41 PM2.5,   WH57 Lightning Detector,   WH31 Temp/Hum x8,  WN34L Liquid Temp x2,  WN34S Soil Temp x1, WH51 Soil Moisture x8,   WH55 Water Leak x4,   Meteobridge (TL-WR902AC v3),   Da9L PWT x2, Home Assistant Integration
Offline _John C
« Reply #7 on: March 10, 2021, 11:15:05 AM »
Problem fixed  [tup]
Meteobridge 5.1 (Mar 10 2021, build 3804)
