OK I got the moon.png 13kb created, correct path to extra webfiles
where exactly do I add the <img src="img/moon.png">
I opened indedx.html with notepad++,from what I've read tags need to be between <body> & <body>
Then on your dashboard page you would have to add an image tag into the html of <img src="img/moon.png">
how do I know where to add it?
I tried on the end of line#129 and got a small page icon with a bent corner
<p><span>Sunrise</span> <span id="Sunrise" class="low"></span> Sunset <span id="Sunset" class="high"></span> Moonrise <span id="Moonrise" class="low"></span> Moonset <span id="Moonset" class="high"></span>(added here)</p>
do I have to create a block to put it in?
or add it after this line
<p><span id="Forecast"></span></p (line #130)
above </div> (line 131)
don't I have to indicate the size of the image in the tag?
<img src="img/moonbaseimage.png" width="200"
height="200">
like that?
Thnx Gold
