Like to help out with hosting costs for WXForum.net? Use the donate page. Thanks!
Do you mean the WiFiLogger sold by Scaled Instruments ?If your WiFi Logger has an SD card slot it is a logger 2. Also the pic I have seen of the logger 2 has WFL 2.0 silkscreened on the board. Both run firmware v2.3 I believe. The only differences are a newer WiFi chip a nd the SD card slot which isn't used at this time and the WL2 is compatible with WL.com and WU with rapidfire. If the last two things aren't important then upgrading won't get you anything extra.https://www.scaledinstruments.com/shop/davis-instruments/hardware-data-loggers-software/hardware-software-bundles/wifilogger2/
