Author Topic: Help Setting up Alt Ajax Dashboard  (Read 828 times)
Offline rlmarcum22
    • East-Central Kentucky Weather
« on: August 06, 2020, 01:28:19 AM »
I need help configuring the alternative Ajax dashboard for my weather website.  Its missing some images like the one under the current temperature and the cloud levels.  Also I need help setting up and fixing the AQI for my area.  Thanks in advance! My website is: www.ekyrrgweather.com
Offline rlmarcum22
Re: Help Setting up Alt Ajax Dashboard
« Reply #1 on: August 06, 2020, 01:52:33 AM »
I also need help fixing my astronomy page, the Sun/moon dial on the right that's showing the wrong time, and fixing the records from weather underground on my temperature! ](*,)
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #2 on: August 06, 2020, 08:33:52 AM »
I noticed you have many scripts out of date on your website.
http://www.ekyrrgweather.com/check-fetch-times.php?show=versions
One of them being advforecast2.php which afaik is the Alt Ajax Dashboard - is it not?
Regards Simon
Offline rlmarcum22
« Reply #3 on: August 06, 2020, 02:38:14 PM »
Why would so many of my scripts be out of date? I just created my website this year. :shock:
Offline Jasiu
    • LexMAWeather
« Reply #4 on: August 06, 2020, 04:47:24 PM »
If you look in the "Released Script Version" column, you'll see the updates are all timestamped in 2020. Like any software, it requires constant maintenance.
https://lexmaweather.info
Offline rlmarcum22
« Reply #5 on: August 06, 2020, 05:17:00 PM »
Ok thanks!
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #6 on: August 06, 2020, 05:17:44 PM »
most of the scripts pull data from other websites that are constantly changing urls, values, etc. Ken does a great job in fixing these script very quickly, but it is a never ending task.  you must keep these scripts up to date, else pages become broken very quickly.
once you have them upto date (and some may require editing before uploading) the url here:
http://www.ekyrrgweather.com/wxstatus.php
will warn you of any script pages that need updating too.
« Last Edit: August 06, 2020, 05:20:16 PM by ConligWX »
Regards Simon
